Fuel tank straps
Old Jun 3, 2012 | 10:57 AM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Fuel tank straps
Hey guys...This is a warning...I almost lost my tank today and slice a hole in the tank itself....This has happened in the past on my truck...There was a slice on the tank that I could not figure out why when I bought the truck...Well today I found out...The front strap snapped and the tank swinged out towards the driveshaft counter balance..The counter balance almost sliced a big hole in my tank again...Which trust me...Once these plastic tanks get a hole in them...There is no way of patching them...I tried...
I was going to get used straps but went with new ones...I'm going to figure out how to install two extra straps...
Old Jun 4, 2012 | 01:20 PM
Lil Dog's Avatar
Warning heard. With all the gravel road my 97 sees, I wonder how bad they are against the frame where I can't see them.
Old Jun 4, 2012 | 01:28 PM
I don't know Jason...Maybe it's just my truck...This is the second time for a snapped front strap...Like I said...Now I know what happened to the first tank...Almost destroyed the second one..
With the size of these tanks full,thats alot of weight for only two straps...Then pound them on pot holes..Something has to give..Would be a real ordeal if the back one let loose at the same time..Now that would be a mess..I noticed the tank is very front end heavy..
Re-inforcement time..
Old Jun 5, 2012 | 11:16 AM
Dr. Evil's Avatar
With the price of fuel I dont have to worry about having a full tank...
Old Jun 5, 2012 | 09:18 PM
Tate's Avatar
Come on, fuel is 9 cents cheaper in Leduc than other places, like Devon. You're in the land of cheap fuel!
Old Jun 5, 2012 | 10:42 PM
torquefan's Avatar
Thanks for the reminder, I saw a bit of corrosion on my straps a while ago, then forgot to do anything about it. Time to get some located.
As far as an auxiliary strap for emergencies, I remember seeing a couple of farm trucks years ago with a chain running under each strap, just in case. Would probably be pretty easy to rig up.
Old Jun 5, 2012 | 11:02 PM
I'm still P'Od.....I have a nice gash on the side of the tank...I was luck it's not through my perfect replacement tank..But it's very close to a hole....
It's my fault for not inspecting my truck on a monthly basis...I have no idea how long the strap was broken...Noticed something hanging under my truck when I was at the Canadian tire parking lot...
I think a good bounch on one good pothole would of ripped the tank right out..
Got the new straps today...
Old Jun 6, 2012 | 09:24 AM
jstone44720's Avatar
I stil lcan't believe those new straps come in raw steel too - powdercoated mine before installing. They are officially the cleanest/least rusty parts on my truck.
I also coated the ends that disappear into the frame with waterproof grease prior to installation. I am counting on that to help some.
Old Jun 6, 2012 | 09:52 AM
StealthDiesel's Avatar
Dave, was the fuel tank strap rusty and then it snapped? If it wasn't rusty, I wonder what caused it to fail?
Also, I thought it was possible to plastic weld/repair plastic fuel tanks, perhaps not?
Great idea.. Powdercoating the straps would be quick, simple & nicely preventative.
Old Jun 6, 2012 | 10:22 AM
Even Rustoleum flat black has to be better than nothing. A friend used some 3M aerosol undercoating on his S-10 straps and they aren't rusty at all after 6 years.
How are the fuel, brake, and E-brake lines and cables holding up? I have had to replace all those on mine within 6 mos to a year of the first strap letting go.
Old Jun 6, 2012 | 11:27 AM
So far the orginal fuel lines are ok...But I did replace bought e-brakes a couple of years ago..
The straps did have rust on them.. thanks for the input...I'm going to coat the new ones with something..
I tried to repair the old tank...With the tank repair plus a large area was fibreglassed on top..Roughed up to make sure it had good tooth..I think the fibreglass didn't work because these plastic tanks do flex alot..It lasted about 2 years before it started to leak again..
Old Jun 6, 2012 | 02:56 PM
Higher end autobody shops do have methods of welding the plastic bumper covers on newer cars. The methods are specifically chosen to promote flex and not re-crack. You might be able to find someone that could do that sort of thing for you if you are still trying to repair the old tank.
What brand and source did you use for the e-brakes? O'reilley's is killing me with wrong/bad parts so I ordered Raybestos from rock auto last night. This is what I'm hoping is the last issue of this kind for me on this truck, and everything has hit within a year of that strap dying.
Stamey
Jun 27, 2008 02:04 PM
Jim5870
May 12, 2007 11:03 PM
ScottN
Mar 28, 2007 07:41 AM
kiszka6911
Sep 20, 2006 07:28 AM
kennedy
Aug 7, 2005 06:55 AM
