Ecm
Old Aug 7, 2010 | 11:10 PM
  #31
han solo's Avatar
dont think a 06 wiring harness is going to fit a 03, alot different in the way they plug into the valve cover base/housing
Old Aug 8, 2010 | 01:12 AM
  #32
morkable's Avatar
isnt it just the 3 square plugs with 4 wires in each of them?
Old Aug 8, 2010 | 02:28 AM
  #33
Tate's Avatar
The 04.5+ have two harnesses that feed three injectors, instead of 3 harnesses that feed two injectors.
Old Aug 8, 2010 | 08:47 PM
  #34
morkable's Avatar
ahh,, I stand corrected. I should pay more attention
Old Aug 9, 2010 | 06:51 AM
  #35
Tate's Avatar
And thats coming from a guy who knows nothing about CR's. You should hang your head in shame!
Old Aug 10, 2010 | 01:41 AM
  #36
morkable's Avatar
yeah I know, I am hanging it
Old Aug 10, 2010 | 12:37 PM
  #37
Mike Holmen's Avatar
The Guru
So Kev, you get it running? You only have a few days before the big race.
Can't you put a volt meter on the injector and see if you get voltage at the injector? How does the injector fire? Is it an AC frequency or something simple like a DC signal (on/off)?
Old Aug 10, 2010 | 02:50 PM
  #38
The Guru
I can't see why you can't hook-up a scope and see what ECM is sending out.
I don't want to try this stuff with my 6.7L, yet, but at some point I want to. You could even set the scope trigger off the crank position sensor to see if injection cycles are firing at the right time.
Wouldn't a piezoelectric injector would be fired binary???
Old Aug 10, 2010 | 09:58 PM
  #39
03 ant a hemi's Avatar
I am not much help but 03 had 11 different ECM configerations due to changes in programming, and some were compatable and some were not with different engines. Changing ECMs around would result in some very different situations. One of them is a mis firing engine.
If you can get ahold of a DRB3 scan tool then you should be able to see if the injector is getting power and firing properly.
Using a volt meter would be hard to tell if voltage is getting their due to the small and quick application.
There is a guy down in Olds that may have a ECm or two kicking around. Not sure what he might charge or loan out, Bernard (403) 938-3888
Old Aug 11, 2010 | 01:47 AM
  #40
morkable's Avatar
I have a tool to reprogram a ecu to work with any truck. I have eliminated that as the problem now. I have pulled the injectors, going to go into each cyl with my boroscope and take a peak. But for this weekend it will be the 13 second ford it looks like. I bought all new o-rings and washers for the injectors. Give that a try. My friend Keith in GP (he is a dodge mechanic) thought that this could be a possiblility. Give that a try tomorrow night.
Old Aug 11, 2010 | 07:24 PM
  #41
huck25's Avatar
My 05 has three plugs for the injector harness not two I think it's 06 and up that only has two.
Old Aug 11, 2010 | 11:43 PM
  #42
rage_blue's Avatar
I'm pretty sure it was 06 they went with the two plug system, they also put on a plastic valve cover. an 06 computer would not work on an older truck as in 06 they went to can communication.
ratat98
Sep 18, 2016 07:34 PM
6spd05Dually
Mar 12, 2011 12:19 PM
jrussell
17
Sep 17, 2007 06:38 PM
Ohio Joe
Jul 12, 2004 12:13 PM
