DSS bearing
Old Aug 7, 2011 | 03:37 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
DSS bearing
Got a email to Harry on this one....Bearing on the DSS is getting bad...A little rough sounding and I had a heck of a time getting the nut out of the bearing.For some reason the centre bearing hole wore on one side...Don't know how they pressed these bearings in...Its not a straight edge bearing but a beveled bearing...May land up buying the complete assembly..
I'm sure getting my share of things breaking this week...
Old Aug 7, 2011 | 04:58 PM
.....I figured it out..Its beveleved because it has to move within the housing...Thats why there is a grease zerk.....Always helps to remove the grease,then check operation....The off centre is also normal.
They must heat the assembly,then drop the bearing in..Still need a bearing..or the whole assembly..The sealed bearing has some rough spots..
Old Aug 7, 2011 | 05:11 PM
maxwellp's Avatar
Talking
.....I figured it out..Its beveled because it has to move within the housing...Thats why there is a grease zerk.....Always helps to remove the grease,then check operation....The off center is also normal.
Its just a pillow block bearing, It should spin up on it's side and pull out. If you have all the grease off it look for two spots on the cast part that look like the metal is missing. But thats what mine looks like, it is also a BD one.
Old Aug 7, 2011 | 05:15 PM
maxwellp's Avatar
Talking
Got a email to Harry on this one....Bearing on the DDS is getting bad...A little rough sounding and I had a heck of a time getting the nut out of the bearing.For some reason the centerer bearing hole wore on one side...Don't know how they pressed these bearings in...Its not a straight edge bearing but a beveled bearing...May land up buying the complete assembly..
The center hole is offset because there is a collar that is also offset that you beat around to lock it on the shaft.
Old Aug 7, 2011 | 07:43 PM
Thanks Max....I will spin the bearing around...Hopefully pops out,then I could source through a bearing shop...
Old Aug 7, 2011 | 08:43 PM
winkdemon's Avatar
you can buy the complete flange bearing a priness auto 19.99
Old Aug 7, 2011 | 08:51 PM
han solo's Avatar
Its used in pretty much everyday farming life, among other things. Like was said, turn the brg 90 degree to the pillow block, then the brg rolls out. I also have the same brace, but on a 03. Should be able to get the brg anywhere.
Old Aug 7, 2011 | 08:53 PM
maxwellp's Avatar
I have to take the one off my 96 because there is a bolt that hold it on broke off. I will post the numbers for it when I get it off. Grainger would have it, it is not really a truck part, more like an air handler bearing.
Old Aug 7, 2011 | 10:02 PM
Thanks....Got the bearing out and even have the bearing number now...
Old Aug 8, 2011 | 09:24 AM
ccmckee's Avatar
Your bearing is bada lready? Holy crap Dave, i put on twice the miles you do and my '96 was still good when i sold it.
Old Aug 8, 2011 | 09:32 AM
And I hardly drive my truck...Maybe the couple of doses of death wobble damaged it..
pmtg
Jul 19, 2007 08:47 PM
Rattletrap1
Jul 11, 2007 12:12 PM
wadecool
Jan 12, 2007 11:39 AM
Joseph H. Smith
16
Jan 6, 2007 08:13 PM
