Downpipe for HE341-HE351 swap
Hi guys, trying to help my unlce do a swap from his HE341 to a 351 but he needs a new downpipe so that he can run the larger elbow off the turbo.
Anyone know a good palce around calgary he could get one?
no change is needed, direct bolt up. you will have to mod the solenoid. as it sits the waste gate will open at 20 psi. the easiest thing to do is to add spring tension to the diaphragm to increase the opening to 33 psi. some change the diaphragm to a adjustable one, bd has both kits. I am lazy and modify my solenoid to make it a adjustable boost elbow so that I can easily adjust it in about 1/4 mile in five minutes to 33 psi
RJ285
Dec 8, 2013 11:41 AM
koondawg
Oct 24, 2012 11:11 PM
5.9 Blackout
Sep 19, 2010 11:01 AM
Big Blue24
Nov 27, 2008 12:36 PM
