24 Valve rebiuld on a shoestring budget. no laughing
#32
Thats what my timing case looks like for the 24v conversion, but like I said, thats a revised unit. They may have come from the factory, but more than likely its after the KDP dropped and cracked the case.
As for the gear, if you're talking about an adjustable pump gear, I have on sitting on the front seat in my dually. Going in on Saturday.
#34
The Guru
Tate, for my 02, can I re-use my cam gear and tach sensor? I'm thinking about just drilling a extra hole in my gearbox to run the wires. Outside of that issue, the P pump should just bolt on.
#35
#37
The Guru
#38
#42
SFA. I got the pump in, but the cover and fan are still out, so its not running yet. I didn't get started till about 4:30 and it gets dark pretty fast now. Finish it up when I get back, whenever that is. I can tell you this, my new lines fit worse than my old lines. Its like a tangled mess, lines looping around each other. I am half tempted to run it with the old lines because I know how to make them fit, but I really don't want to damage the pump.
#44
The Guru
Tate, what is that pin looking thing on the back side of the 12V gearbox. On my mock-up 12v, its not attached to anything. I thought you can adjust your IP timing with that pin.
#45
It locks the cam gear at TDC on #1 compression stroke. Its for setting the timing and doing valve lash. Never used it before, much easier ways than that.
roxxx
ABDTR #5
11-25-2008 01:48 PM
K RUSSO
03-17-2007 10:25 AM
