wiring in my flat bed on my 2016 need some help!
Old Apr 1, 2016 | 06:22 PM
terp393's Avatar
OK I'm starting the project of installing my bradford built flat bed tomorrow and i was going over the wiring just to be prepared. I have it all pretty much sorted out for the blinkers back up and brake lights i just have a last wire in the wiring harness on the flat bed that is for clearance lights (running/marker lights) I'm not sure sure where i would tire this wire into everything is getting connected using weather pack connectors just for ease of removal if i have to take the bed off for what ever reason, if anyone has some insight on this that would be awesome
Old Apr 1, 2016 | 09:52 PM
Hillbilly66's Avatar
The clearance/marker/running lights should be wired to come on with the tail lights.
Old Apr 1, 2016 | 09:56 PM
terp393's Avatar
so i guess i would buddy that wire up with either the left or right side power for the brake light theres 3 wires going into the stock socket the brake light blinker and ground
Old Apr 1, 2016 | 10:01 PM
Of those three wires brake lights and turn signals are the same wire, ground is one wire, and the third is the tail light. Use the tail light wire for the running lights.
Old Apr 1, 2016 | 10:08 PM
terp393's Avatar
got ya so the brake and turn signal are gona be buddied up together now i got it, when it comes to wiring I'm not that sharpest bowling ball lol i can splice the brake and turn together into one wire and put that into my weather pack
Old Apr 1, 2016 | 10:32 PM
I was that way once with wiring, it gets easier with time and patience. Yes the brake and turn wires for each side can go to one wire in your weather pack.
Which Bradford Built bed did you get? I am looking at getting their "work bed" myself.
Old Apr 2, 2016 | 06:21 AM
terp393's Avatar
i have the aluminum work bed I'm going to make a new thread on the install when I'm donne so i post up some pictures
Old Apr 2, 2016 | 06:29 AM
Very nice. I like the look of those. Looking forward to seeing it installed.
12valvin
Mar 8, 2011 12:02 PM
Markal05
Mar 10, 2010 10:45 PM
Mark Hodowanec
Jul 16, 2006 04:05 PM
Mark Hodowanec
Feb 24, 2006 04:22 PM
