Steering Stabilizer
Steering Stabilizer
Looking at the ads in Diesel Power for these Steering stabilizers. I cannot see the benefit as much as I would see from using an aftermarket track bar kit and even solid bushings in the upper and lower control arms. Am I correct here? I cannot even figure out what this stabilizer does. After all I believe the steering gets loose as the bushings in the aforementioned stock parts get softer right? Isn't the chassis area where the steering box is nice and solid or does this part strengthen that area. Please, if someone could chime in and advise. I don't like chucking useless $$ at the truck.
Frankly, the only issue I have had with my 4x4 Rams (on my fifth now so have some experience) is that the larger tire/wheel combos when hitting bumps can yank the steering one way or the other - which I've cured by having the double horizontal shock absorbers on the steering arm. Seems like the stock shock is only good for (and just barely) the stock tire/wheel. I have had two-inch square tube crossmembers welded between the rails up front to mount a receiver hitch and tow plates on on the last two trucks, so that may have unintentionally cured any looseness from frame rail flexing - but I'm having a hard time buying that that is really what happens (flexing frame rails).
I have been running a KORE stabilizer since '06. It was best 500 bucks I spent and I swapped it over to the '11. Its nitrogen charged and adjustable, I keep mine at 60psi and the truck tracks straight with 12.50-35"s.
Is that the "Race Series Steering Damper" they talk about, with the Bilstein 7100 "shock"?
I installed a steering box stabilizer on my truck and I`am very happy with it. It was well worth the money because it does keep my truck from wandering down the road. Its relay noticeable when I haul my fiver . I`am not at the wheel correcting the truck from following the hollows on the pavement. This is one of a few good things I have tried That I read on this site. Thanks again guys. later Don T
OK I found more info. The item I was referring to is a chassis/steering box support. Cost is $245 CDN plus shipping. Check out www.solidsteel.biz/ I believe DonT has the same thing on his truck.
The DSS steering brace is a bearing and shaft that add under the steering gear box. Help to reinforce the gear box as tend to they flex. I have them on my of 02 trucks. Help to reduce steering wheel wiggles (death wobble), really needed for the guys that run the big tires.
Steering stablizer is a hydraulic/gas shock that helps to elimate death wobble. The twin stablizer shocks are sweet deal. I run a kore on one of my trucks and a BDS dual on my other truck.
mercedeezel
13
Oct 13, 2013 12:43 AM
EdmontonCanada
Jul 20, 2010 03:57 PM
1985cucv
Jul 31, 2009 02:33 AM
Rattlerattle
Aug 19, 2008 04:14 PM
13ALPHA
Jul 8, 2008 11:31 PM
