Question about cab lights
Old Aug 24, 2011 | 02:41 PM
yellowhemi's Avatar
I would like to have the cab lights installed like the 3500's have. The factory ones are rediculously expensive. Anybody running aftermarket brands that they are happy with? Any that you would say to stay away from? Thanks.
Old Aug 24, 2011 | 03:07 PM
cbrahs's Avatar
i had RECON on my last megacab. it did not have lights so I had to drill etc. I made my own harness. Cut the RECON silly plug off and hard wired (soldered and heat shrink). USE SILICONE on the holes, even if removing the factory ones and re-installing. an ounce of prevention.......
Mine NEVER leaked (over 4 years installed, zero failures, zero leaks, zero issues)
Old Aug 24, 2011 | 06:09 PM
NB64's Avatar
The factory lights aren't that bad here.. But I think you still need the harness.
http://www.leeparts.com/2009_dodge_r...nce_lamps.html
Old Aug 24, 2011 | 06:16 PM
cbrahs's Avatar
harness is EASY to make. on the right A pillar, there is a plug that is at the base near the dash. test light the harness and find the power with headlights on and there ya go.
Old Aug 24, 2011 | 11:56 PM
Curtis s's Avatar
got recons on mine no problem at all. love them
Old Aug 25, 2011 | 08:41 AM
txhawg's Avatar
Sheesh! They're expensive after the fact! I'm glad I included them in my order
Old Aug 26, 2011 | 10:50 PM
Fanged03's Avatar
If your truck doesn't have any, how do you measure out where they go? Is there a template you can place on the cab to figure out where to drill? Cause I'm liking those Recons in smoke.
Old Aug 27, 2011 | 07:56 AM
yellowhemi's Avatar
Yes, they come with a template.
Old Aug 27, 2011 | 08:13 AM
cbrahs's Avatar
last set of RECONS i installed did not have a template but they could have changed and added one. we used a Dodge template from a buddy
rollerink
Apr 9, 2008 08:47 PM
cummins dsl
22
Jun 27, 2005 11:53 AM
MoreSmoke
22
Jan 10, 2005 03:05 AM
CHarlan
Aug 6, 2003 08:40 PM
