Light Load Switch and Tire Pressure
Old Jan 7, 2011 | 08:54 AM
JAM's Avatar
JAM
Guys,
I think I’m running way too much tire pressure in my TOYO MT's. I have them all set around 60-63 #. First, is this too much if not towing? Second, if it is, where do I turn off the low pressure light, or do I have to back the tire pressure down to a certain # to activate the light load pressure sensor?
I was running around 55lbs in the rear and even with the light load activated, it still gave me the low tire pressure warning.
I ran 50 # in my old MEGA cab (HEMI, light load was no option) with same tire and got 50K miles out of them, so I want to try and get the same performance out of these, just a bit worried about over inflation.
Just looking for some advice on what works best.
Thanks
JAM
Old Jan 7, 2011 | 09:17 PM
brophyn70's Avatar
There should be a button under your radio that says "tire pressure light load" on it
Old Jan 8, 2011 | 02:39 PM
JAM's Avatar
JAM
Yes i have used this button but iot does nothing, when it's turned on to light load, it states that there is not enough tire pressure in the tires and the warning light comes on.
I'm wondering if i have to go below 50# when using the light load for it to work correctly and not give me a warning.
Old Jan 8, 2011 | 03:59 PM
SpectreBoy's Avatar
All I can tell ya is I have 48 psi in the rears and 58 in the fronts and can click it to low pressure and don't get a warning light.
Old Jan 8, 2011 | 05:03 PM
brophyn70's Avatar
it should say what your max PSI is on the inside of your drivers door.
hoot
Mar 14, 2011 04:43 AM
SuperDutyDave
Oct 18, 2009 09:36 PM
rbrettctd
Oct 27, 2008 01:38 PM
Prodart440
Mar 31, 2008 07:22 PM
carwash
Sep 12, 2007 11:39 AM
