Cabin Filter Mod
Not sure why it's taken so long to get this done, but I was looking at prices for the components on the interweb and found this place that put together a "kit". It can be bought cheaper elsewhere, but thought it was interesting that a vendor mated them.
http://allmoparparts.com/1500-cabin-filter-p-3863.html
That certainly is a good price I paid more than that for just the cover. They do catch a ton of junk but the price of filters has kept increasing in leaps and bounds, some places want $34 for just the filter. I made up a washable one then I thought that a 3M electrostatically charged furnace filter would do a better job so I took one that has the aluminum retainer on both sides and cut into 6 filters around the outside, cost was just over $2 each.
Did the Cabin filter mod yesterday. Easy mod, the hardest part was contorting my body to cut the hole! I didn't heat the blade up, I just used a brand new sharp blade. It cut pretty easy(thin plastic) I just followed the outline at an angle, filter slid right in and cover snapped on. Thanks to Geno's! I got a Mopar Cover and a Wix charcoal filter $25.95. Now see how long the filter last. May put a "Hog hair" filter in if the Wix gets full quick, then I'll have a reusable filter. Thanks for the Post, I never would of known I could filter the incoming debris.
I am down in Yuma right now and decided to buy some extra filters to take home and just about fainted when I found the filters had doubled and tripled in price since last year. Can someone explain how to make up our own filters and where do buy them and what size would work?
If you look back through this thread it explains how to make cleanable ones but I made 6 from a single 20X25 3M electrostatically charged furnace filter from Costco in a 3 pack, one that has the aluminum mesh on both sides. Cost was about $2 each, they don't look as pretty but do the job. I used tin snips and cut from around the outside of the filter to the same size as the original one.
It's close if I remember but could always make a washable one from a washable furnace filter, the draw back with the washable one is the frame cuts down on the surface area where the 3M ones don't, you get full airflow plus the amount of things the 3M filters stop is incredible, they are listed on the package.
The 3M filter has aluminum mesh on both faces of the filter not the edges, I use them in my house furnace and they catch very fine dust that would normally go through a cheap filter because of this the filter can become clogged quickly, I think 3M uses the mesh to prevent the filter from collapsing if it becomes clogged.
