AC oil requirement 6.7 liter 2010
Old Oct 18, 2016 | 09:01 PM
Brian Guy's Avatar
2010 Dodge Ram 2500 Laramie, Megacab, automatic, 6.7 liter, 4wd. I had an Evap core leak. I replaced the Evap core and hooked up Freon lines and pulled vacuum. I let pump run for 40+ minutes but did not see any oil come out of exhaust on vacuum pump. I unhooked pump and let it sit 6 hours with no change in vacuum. I know the old evap core was leaking, it had Freon/oil all over one side of it. Can I assume that there is no oil left in system after pulling the vacuum, even though I didn't see any more come out of the vacuum pump,and add the recommended amount as if it were empty? If so how much would that be? If not, then what should I add?
Thanks,
Brian Guy
Old Oct 22, 2016 | 02:05 AM
Brian Guy's Avatar
Nevermind. I found you don't have to add oil unless you replace condenser, compressor, or dryer. Just add Freon. It's running good now.
JeffIvie
Dec 26, 2013 05:33 PM
kawi700
Mar 25, 2011 11:07 AM
kawi700
Introductions / New People
Mar 23, 2011 07:03 PM
DuallyJeff
Dec 15, 2003 08:30 AM
