4th Gen Torque Specs
Old Jul 7, 2011 | 01:58 PM
cbrahs's Avatar
Shock Absorber Upper Nut 40ftlbs
Shock Absorber Lower Bolt 100ftlbs
Shock Tower to Frame 55ftlbs
Lower Ball Joint Nut Initial Torque 35ftlbs
Lower Ball Joint Nut Final Torque 148ftlbs
Upper Ball Joint Nut 70ftlbs
Lower Control Arm Frame Nuts 200ftlbs
Lower Control Arm Axle Nut 200ftlbs
Upper Control Arm Frame Nuts 120ftlbs
Upper Control Arm Axle Nut 120ftlbs
Stabilizer Bar Frame Bolt 45ftlbs
Stabilizer Link Axle Bracket 110ftlbs
Stabilizer Link Stabilizer Bar Nut 27ftlbs
Stabilizer Link Axle Bracket (Power Wagon) 110ftlbs
Stabilizer Link german torque
Stabilizer Bar Nut (Power Wagon) 110ftlbs
Hub/Bearing Bolts 149ftlbs
Axle Nut 132ftlbs Beginning Torque, Then Rotate 5 to 10 Times With a Final Torque of 263ftlbs
Track Bar to Frame (2500/3500 4x4) 200ftlbs
Track Bar to Axle (2500/3500 4x4) 200ftlbs
Tie Rod End Nut 55ftlbs
ABS Assembly Mounting Bolts 11ftlbs
ABS Assembly ABM Screws 31 inlbs
ABS Assembly Brake Line Fittings 170 inlbs
Dynamics Sensor 97 inlbs
Wheel Speed Sensors, Front Sensor Bolt 190 inlbs
Wheel Speed Sensors, Bracket To Knuckle 60 inlbs
Wheel Speed Sensors, Rear Sensor Stud 200 inlbs
ABM Mounting Screws 53 inlbs
RWAL Module Mounting Bolts 11ftbls
RWAL Valve Brake Line Fittings 170 inlbs
Rear Wheel Speed Sensor Mounting Bolt 200 inlbs
Brake Booster Mounting Nuts 21 ftlbs
Master Cylinder Mounting Nuts 160 inlbs
Reservoir Retaining Screws 6 ftlbs
Caliper Bleed Screws 14 ftlbs
Caliper Mounting Pins, Front 24ftlbs
Caliper Mounting Pins, Rear 22 ftlbs
Caliper Adapter Mounting Bolts, Front (1500) 130ftlbs
Caliper Adapter Mounting Bolts, Front (2500/3500) 275ftlbs
Caliper Adapter Mounting Bolts, Rear (1500) 120ftlbs
Caliper Adapter Mounting Bolts, Rear Upper (2500 and 3500) 163ftlbs
Caliper Adapter Mounting Bolts, Rear Lower (2500 and 3500) 190ftlbs
Junction Block Bolts, Front (1500) 14ftlbs
Junction Block Bolts, Rear (1500) 18ftlbs
Junction Block Bolts, Rear (2500/3500) 7.5ftlbs
Brake Pedal Assembly Bracket Bolts (1500) 23ftlbs
Brake Pedal Assembly Bracket Nuts (2500/3500) 21ftlbs
Support Plate Mounting Bolts/Nuts (1500) 75ftlbs
Support Plate Mounting Bolts/Nuts (2500/3500) 150ftlbs
Brake Line Fittings, Master Cylinder 14ftlbs
Brake Line Fittings, Junction Block (Both) 14ftlbs
Caliper Brake Line Banjo Bolt, Front 20ftlbs
Caliper Brake Line Banjo Bolt, Rear 20ftlbs
Brake Hose Bolts To Frame, Front 7.5 ftlbs
Brake Hose Fitting 14ftlbs
Parking Brake Pedal Assembly (1500) 18ftlbs
Parking Brake Pedal Assembly (2500/3500) 14ftlbs
Hub/Bearing Bolts (1500) 120ftlbs
Rotor to Hub Bolt, Rear (2500 and 3500 DRW) 114ftlbs
Extension to Rotor Nut, Front (2500 and 3500 DRW) 128ftlbs
Hub/Bearing Bolts, Front (2500 and 3500 4X2) 130ftlbs
Pitman Arm Gear Shaft Nut (2500, 3500) 177ftlbs
Drag Link to Pitman Arm (2500, 3500) 100 ftlbs
Drag Link to Tie Rod (2500, 3500) 100 ftlbs
Drag Link Adjuster Clamp (2500, 3500) 40 ftlbs
Tie Rod End to Knuckle (2500, 3500) 78 ftlbs
Tie Rod End Adjuster Clamp (2500, 3500) 40 ftlbs
Stabilizer Bar Link to Axle (2500, 3500) 50 ftlbs
Steering Damper to Axle or Linkage(2500, 3500) 75ftlbs
Steering Damper Bracket U-Bolt Nuts (2500, 3500) 45 ftlbs
Track bar to Axle - M16 fastener (2500, 3500) 200 ftlbs
Track Bar to Frame - M16 fastener (2500, 3500) 200 ftlbs
Old Jul 11, 2011 | 12:06 PM
cbrahs's Avatar
Lug Nut 9/16 X 18 with 60° Cone 130 ftlbs
Lug Nut 9/16 X 18 with 60° Cone (2500, 3500 - SRW) 140ftlbs
Lug Nut 9/16 X 18 with Flat Washer (3500 - DRW) 145ftlbs
Lug Nut 9/16 X 18 with Flat Washer (4500, 5500 - DRW) 148ftlbs
Spare Tire Winch 15ftlbs
Jounce Bumper Bolts 21.5ftlbs
Shock Absorber, Lower Nut/Bolt 100ftlbs
Shock Absorber, Upper Nut/Bolt 100ftlbs
Spring Clamp U-Bolt Nuts 110ftlbs
Spring Front Nut/Bolt to Frame 254.5ftlbs
Spring Shackle Nut/Bolt, Upper/Lower 160ftlbs
Old Jul 11, 2011 | 04:23 PM
Hairy1's Avatar
From: Adirondacks of New York and Daytona Beach FL.
Great Information to have on hand........Thanks
Old Jul 11, 2011 | 04:25 PM
cbrahs's Avatar
will be able to add more tonight. have full engine tq specs but am going to do those on a PDF so everyone can see them and how they read cause a lot of them are like 50ftlbs and another 60 degree turn. would be difficult to do it like i have been doing. maybe I will redo all of them and add them to a PDF so they can be printed out. will take a couple hours to do it but worth it so everyone can have specs saved on their computers
Old Oct 25, 2011 | 06:56 AM
New2Diesel's Avatar
"Gomer Pyle"
Thank you for your time and effort in providing this for all of us. When I finally get home I will need alot of these to put my parts on the truck.
Again, much appreciated
Old Dec 2, 2011 | 08:50 PM
burlhall's Avatar
Anyone know what the torque specs are for the bolts that attach the cab to the frame. I had to remove these bolts to install steps and I'm not sure how tight to reinstall them. I am a little concerned because these are the bolts that also hold the rubber cab shocks in place.
Old Apr 9, 2014 | 08:08 PM
jadocs's Avatar
Very helpful, thank you
Old Oct 30, 2016 | 10:21 AM
Thump's Avatar
Thanks for the info, used it yesterday doing rear rotors on my DRW.
Question: rear DRW axle bearing nut torque spec?
I did it the way I used to do all serviceable wheel bearings, but wonder if there's a spec on it.
Thanks
robby t
May 3, 2013 08:58 PM
lniemeyer2
Oct 24, 2012 12:11 PM
Blake Clark
May 17, 2010 05:23 AM
earpp
Introductions / New People
Jul 31, 2008 05:34 PM
06RAMCTD
0
Dec 19, 2006 04:15 PM
