4th Gen Torque Specs
Shock Absorber Upper Nut 40ftlbs
Shock Absorber Lower Bolt 100ftlbs Shock Tower to Frame 55ftlbs Lower Ball Joint Nut Initial Torque 35ftlbs Lower Ball Joint Nut Final Torque 148ftlbs Upper Ball Joint Nut 70ftlbs Lower Control Arm Frame Nuts 200ftlbs Lower Control Arm Axle Nut 200ftlbs Upper Control Arm Frame Nuts 120ftlbs Upper Control Arm Axle Nut 120ftlbs Stabilizer Bar Frame Bolt 45ftlbs Stabilizer Link Axle Bracket 110ftlbs Stabilizer Link Stabilizer Bar Nut 27ftlbs Stabilizer Link Axle Bracket (Power Wagon) 110ftlbs Stabilizer Link german torque Stabilizer Bar Nut (Power Wagon) 110ftlbs Hub/Bearing Bolts 149ftlbs Axle Nut 132ftlbs Beginning Torque, Then Rotate 5 to 10 Times With a Final Torque of 263ftlbs Track Bar to Frame (2500/3500 4x4) 200ftlbs Track Bar to Axle (2500/3500 4x4) 200ftlbs Tie Rod End Nut 55ftlbs ABS Assembly Mounting Bolts 11ftlbs ABS Assembly ABM Screws 31 inlbs ABS Assembly Brake Line Fittings 170 inlbs Dynamics Sensor 97 inlbs Wheel Speed Sensors, Front Sensor Bolt 190 inlbs Wheel Speed Sensors, Bracket To Knuckle 60 inlbs Wheel Speed Sensors, Rear Sensor Stud 200 inlbs ABM Mounting Screws 53 inlbs RWAL Module Mounting Bolts 11ftbls RWAL Valve Brake Line Fittings 170 inlbs Rear Wheel Speed Sensor Mounting Bolt 200 inlbs Brake Booster Mounting Nuts 21 ftlbs Master Cylinder Mounting Nuts 160 inlbs Reservoir Retaining Screws 6 ftlbs Caliper Bleed Screws 14 ftlbs Caliper Mounting Pins, Front 24ftlbs Caliper Mounting Pins, Rear 22 ftlbs Caliper Adapter Mounting Bolts, Front (1500) 130ftlbs Caliper Adapter Mounting Bolts, Front (2500/3500) 275ftlbs Caliper Adapter Mounting Bolts, Rear (1500) 120ftlbs Caliper Adapter Mounting Bolts, Rear Upper (2500 and 3500) 163ftlbs Caliper Adapter Mounting Bolts, Rear Lower (2500 and 3500) 190ftlbs Junction Block Bolts, Front (1500) 14ftlbs Junction Block Bolts, Rear (1500) 18ftlbs Junction Block Bolts, Rear (2500/3500) 7.5ftlbs Brake Pedal Assembly Bracket Bolts (1500) 23ftlbs Brake Pedal Assembly Bracket Nuts (2500/3500) 21ftlbs Support Plate Mounting Bolts/Nuts (1500) 75ftlbs Support Plate Mounting Bolts/Nuts (2500/3500) 150ftlbs Brake Line Fittings, Master Cylinder 14ftlbs Brake Line Fittings, Junction Block (Both) 14ftlbs Caliper Brake Line Banjo Bolt, Front 20ftlbs Caliper Brake Line Banjo Bolt, Rear 20ftlbs Brake Hose Bolts To Frame, Front 7.5 ftlbs Brake Hose Fitting 14ftlbs Parking Brake Pedal Assembly (1500) 18ftlbs Parking Brake Pedal Assembly (2500/3500) 14ftlbs Hub/Bearing Bolts (1500) 120ftlbs Rotor to Hub Bolt, Rear (2500 and 3500 DRW) 114ftlbs Extension to Rotor Nut, Front (2500 and 3500 DRW) 128ftlbs Hub/Bearing Bolts, Front (2500 and 3500 4X2) 130ftlbs Pitman Arm Gear Shaft Nut (2500, 3500) 177ftlbs Drag Link to Pitman Arm (2500, 3500) 100 ftlbs Drag Link to Tie Rod (2500, 3500) 100 ftlbs Drag Link Adjuster Clamp (2500, 3500) 40 ftlbs Tie Rod End to Knuckle (2500, 3500) 78 ftlbs Tie Rod End Adjuster Clamp (2500, 3500) 40 ftlbs Stabilizer Bar Link to Axle (2500, 3500) 50 ftlbs Steering Damper to Axle or Linkage(2500, 3500) 75ftlbs Steering Damper Bracket U-Bolt Nuts (2500, 3500) 45 ftlbs Track bar to Axle - M16 fastener (2500, 3500) 200 ftlbs Track Bar to Frame - M16 fastener (2500, 3500) 200 ftlbs |
Lug Nut 9/16 X 18 with 60° Cone 130 ftlbs
Lug Nut 9/16 X 18 with 60° Cone (2500, 3500 - SRW) 140ftlbs Lug Nut 9/16 X 18 with Flat Washer (3500 - DRW) 145ftlbs Lug Nut 9/16 X 18 with Flat Washer (4500, 5500 - DRW) 148ftlbs Spare Tire Winch 15ftlbs Jounce Bumper Bolts 21.5ftlbs Shock Absorber, Lower Nut/Bolt 100ftlbs Shock Absorber, Upper Nut/Bolt 100ftlbs Spring Clamp U-Bolt Nuts 110ftlbs Spring Front Nut/Bolt to Frame 254.5ftlbs Spring Shackle Nut/Bolt, Upper/Lower 160ftlbs |
Great Information to have on hand........Thanks
will be able to add more tonight. have full engine tq specs but am going to do those on a PDF so everyone can see them and how they read cause a lot of them are like 50ftlbs and another 60 degree turn. would be difficult to do it like i have been doing. maybe I will redo all of them and add them to a PDF so they can be printed out. will take a couple hours to do it but worth it so everyone can have specs saved on their computers
Thank you for your time and effort in providing this for all of us. When I finally get home I will need alot of these to put my parts on the truck.
Again, much appreciated |
Anyone know what the torque specs are for the bolts that attach the cab to the frame. I had to remove these bolts to install steps and I'm not sure how tight to reinstall them. I am a little concerned because these are the bolts that also hold the rubber cab shocks in place.
Very helpful, thank you
Thanks for the info, used it yesterday doing rear rotors on my DRW.
Question: rear DRW axle bearing nut torque spec? I did it the way I used to do all serviceable wheel bearings, but wonder if there's a spec on it. Thanks |
