Power wire on minimax
Old Jun 11, 2011 | 04:16 PM
JARHEAD's Avatar
What are most of you doing with the power wire? Drilling small hole through box., from underneath, or just putting the lid down on top of wire??? Also, the instructions say nothing of it, but obviously the other wire is a ground. Y'all running it to the chassis just somewhere near fuse box??
Old Jun 11, 2011 | 04:41 PM
New2Diesel's Avatar
"Gomer Pyle"
I drilled a small cut-out in the fusebox and tied into the H&S recommended location. This will allow the wire to go into the fuse box without closing down on it.
Old Jun 11, 2011 | 04:58 PM
JARHEAD's Avatar
Gotcha. What about the ground?
Old Jun 11, 2011 | 05:23 PM
New2Diesel's Avatar
"Gomer Pyle"
I used on of the grounds not too far away. I believe it was pre-existing but I am not sure. I will go check and then confirm.
Old Jun 13, 2011 | 05:05 AM
redlineguy's Avatar
Same here. Small slot on edge of lid and a little calk.
Old Jun 13, 2011 | 06:49 PM
JARHEAD's Avatar
yep, exactly what i did and it ended up with a nice clean and hidden look. I used that ground that is right on the fender adjacent from the fuse box.
JARHEAD
Jun 11, 2011 03:21 PM
Txwelder
Feb 11, 2006 10:32 AM
matthopp
May 11, 2004 04:38 PM
TPilaske
16
Nov 22, 2002 08:15 PM
