2 Questions: Homelink and H&S Minimax
Old Jun 9, 2011 | 10:17 PM
JARHEAD's Avatar
Homelink: Having trouble getting it to work. Doing everything just as the manual says. garage door opener working correctly and it is almost new. Anyone had any problems?
Minimax: I have the minimax that was installed in the ford. For putting in the 2011 dodge, i know it will cutoff the egr electronically, but with the dpf, what is the deal with that? I do not have the pipe yet, but want to go ahead and install programmer. Am i good to go on that? with the ford programming, you can choose between using hte delete kit or not. is it the same with the dodge?
Thanks for the help...
Old Jun 9, 2011 | 10:21 PM
cbrahs's Avatar
homelink- if you have a newer garage door with rolling codes, you must call homelink and have them go over programming with you.
if you leave the DPF on, and have the mini tuned for dpf removed, it will plug up the dpf pretty fast and start choking out your motor. yes it is the same as the ford programming in the sense you choose if DPF has been removed or not.
Old Jun 9, 2011 | 10:27 PM
JARHEAD's Avatar
easy enough. with the dpf still on, but egr turned off, will i still see some decent improvement?
Old Jun 9, 2011 | 10:28 PM
cbrahs's Avatar
yes. you will be more than happy
Old Jun 10, 2011 | 06:40 AM
djcheez's Avatar
Ditto
Old Jun 10, 2011 | 08:40 PM
doorguy's Avatar
Did you get your homelink working?
Do what the manual says, once the remote is programed to the homelink (one of the three buttons) you have to find the learn button on the garage door opener itself. You push and release the learn learn button run back to the truck and push the homelink button you programed the remote to, you will have to push it at least two times maybe three.
Old Jun 10, 2011 | 09:00 PM
gunner_herman's Avatar
minimax
I put the mini on my 2011 a few months ago and couldn't be happier with the difference. I took of the dpf and the nos and replaced them with a straight pipe. The monitor runs through a series of prompts allowing you to select whether or not you still have the dpf installed. The best part was not having to do anything to the egr; the programmer simply turns it off. My mileage went up about 2-3 mpg, but since I don't have to worry about the regens anymore I expect the mileage to be consistently better than stock.
Old Jun 10, 2011 | 11:30 PM
JARHEAD's Avatar
Did not get a chance to mess with the homelink today, will take what you said and try it out tomorrow if i in fact actually get to have a saturday to do what I want to....
Old Jun 11, 2011 | 03:21 PM
JARHEAD's Avatar
Doorguy, did exactly what you said on the opener and it worked!!! Thanks!!! Now back to staining the house.
JARHEAD
Jun 13, 2011 06:49 PM
BMH95
Aug 19, 2006 08:07 PM
CaughtinmyGrill
19
Oct 1, 2004 02:33 PM
stevenknapp
13
Feb 3, 2004 03:25 PM
