Just installed H&S BLMX and Deletes
Any of you guys run H&S without the tranny tune? I just running the standard programmer and really don't think I need the overdrive.
I already paid a ton of cash for the programmer. Fords guys get their trans tune free.
Mike, I loaded my stock tune just to make sure I could put back to stock with no issues. After that I loaded the Full Delete tune and did not load the transmission tune. Basically I just did not enter my UNLOCK code and then drove the truck. What I noticed was that the TC LOCKED indication on my Mini Maxx rarely happened. Also, almost every time I applied light throttle application it wanted to shift down instead of just increasing boost. It also shifts much softer without the trans tune.
I then loaded the tune again, entering my unlock code, and took for a drive. TC LOCKED shows almost immediately in every gear it shifts to, shifts are much harder and faster, and when I put some serious throttle in it there was way less "BOOST CREEP" and "DOWN-SHIFTING". I cannot tell you that it was worth it but I can tell you that it makes a noticeable difference.
I will get back to you after I drive it more and do some testing. I am also gonna do some DRAG testing once the weather in NC gets better.
I am not sure if you will see any difference on the highway. I would guess that the more you stay in 5th or 6th cruising the less you would need the trans tuning. I drive pretty much only city so it works fab for me. By the way I am sending the "Full Delete" pics to Blake now so keep looking.
shlen
16
Nov 10, 2011 07:43 PM
VegiRam
Jun 2, 2011 01:36 PM
thaimonkee
Mar 3, 2011 08:15 AM
klx650a2
20
Jun 11, 2010 04:33 PM
2171CTD
Mar 16, 2010 10:08 PM
I thought that the H&S tune without overdrive, works awesome as it. I do more hiway driving that city.
