Has anyone put a smarty jr on a 2010 yet
Old Feb 24, 2011 | 07:13 AM
justcampin's Avatar
Has anyone put a smarty jr on a 2010 yet, if so tell us about it
Old Feb 24, 2011 | 07:24 AM
signature600's Avatar
Typical Smarty experience
Chris
Old Feb 24, 2011 | 07:45 AM
Blake Clark's Avatar
Hey chris
You do an intake with that smarty.
Any codes?
Old Feb 24, 2011 | 02:26 PM
Nope, stock intake. I still haven't seen anything designed and SURE to fit the 2010's
Chris
Old Feb 27, 2011 | 08:42 AM
Mike Holmen's Avatar
The Guru
Heard that a few local trucks got dusted engines from aftermarket intakes. So be carefull on what you buy.
I'm running stock intake on both of my trucks. Every aftermarket CAI I had, my turbo impeller/compressor housing got dirty. Even my intake plenum on the head had an oil film.
Old Feb 27, 2011 | 11:27 AM
justcampin's Avatar
So if you don't do a dpf deleate, will it get pluged after a while?
Old Feb 27, 2011 | 05:34 PM
It shouldn't if you run the standard tuning, not the ME tuning
Old Mar 1, 2011 | 06:53 AM
justcampin's Avatar
What kind of mileage are you getting now
Old Mar 1, 2011 | 10:14 AM
13-14mpg
Chris
Old Mar 11, 2011 | 08:07 AM
Anyone else installed a Smarty yet??
Chris
Old Mar 11, 2011 | 09:36 AM
ranchertx's Avatar
I will be doing it this weekend, will report back. Going DPF delete and Smarty ME.
Old Mar 14, 2011 | 08:35 AM
ranchertx's Avatar
Mine is on! No problemo. Runs great, looks like she is gonna get about 20 HWY on flat ground with minimal wind.
Much better throttle response.
The only problem I had was the exhaust clamp did not want to tighten enough when I put the delete pipe in. I had to improvise.
Old Mar 14, 2011 | 11:27 PM
jnovak's Avatar
How fast were you going to get the 20 mpg? Also, were you using the cruise or peddling?
Old Mar 15, 2011 | 12:51 PM
ranchertx's Avatar
69 MPH flat ground, no wind, looks to be right at 20 MPG.
Just drove up and picked up 3 tons of feed on a 25' Float, wind blowing 20 MPH at 90 degrees, got 13.9.
Old Mar 16, 2011 | 01:26 PM
nhrangerjoe's Avatar
I will have a smarty jr on this afternoon. I will be running the truck "stock" to see how it does and hopefully when the funds come avalible delete everything. I will post numbers after the first tank is ran through with the smarty.
