Deleting the 6.7: A guide to making it run right! (4th Gen Section) UPDATED 6-6-11
#213
I'm not much help, but you may want to just start a new thread to get a little more exposure for your question.
In the mean time, have you thoroughly read the instructions provided for your Smarty or researched Smarty's website to see if they have the answer?
If I remember correctly "catcher" stands for Clutch And Traction Challenger...not really sure what it means, but I believe it has something to do with throttle response and possibly the SW settings. It is probably all on your Smarty, but my recommendation to you would be to get out the manual and thoroughly research everything your tuner can do. Check out MADS website for further info, and lastly search on this forum (TONS of info on here). I believe, just like the H&S tuners, the higher the level, the higher your chances are of possibly breaking something due to the increased HP and torque.
Be safe and have fun playing with your Smarty...or your truck rather.
#214
I pluged it in and nothing unknown software! I was all set to start. I had my air tools out everything set up. Wife left me alone. I thought I better try the programmer first. Then the day was lost. I could not get it to work.
This week plan B.
This week plan B.
#215
9000 miles fully deleted on my 2012 2500, from 1000 miles on odometer.first 1000 miles avg 11.68mpg. since then a worst of 15mpg and a best of 19.5. all hand calculated.
h&s minimax, 4" turbo back exhaust.
#216
I sent my smarty back to get reprogramed. I can not do anything like that. Thank God for Rollin Smoke Diesel. Jimmy talked to me Saturday and Sunday and wanted to help me di it.
I would not put him through that so I sent it to him to fix it.
I can not wait. Reading about trucks the go from 12 to 15 makes it worth it.
#217
All the deletes are complete. I needed a head gasket done and warranty won't cover because of Mods. What should the shop time be for re/re a head? I purchased the aftermarket studs and did the egr cooler delete now as well as the throttle body. Hoping now the air filter will stay cleaner or that is the next thing that gets changed out.
#218
first of abig thank-you to blake and helpers for the write up.
so after reading all 15 pages, i have a couple of questions.
on picture #13 you talk about just going with an aftermarket intake, what did you use, is there a "best" one to use?
i live in the cold 8 months of the year, would this involve removing the grid heater when you put on an aftermarket intake? should i be removing the grid heater given that i live/work in northern alberta/bc? any other pipes or tubes i should be looking at changing when going with a aftermarket intake? if i do remove the grid heater is it simply remove and tape off wires or is there a delete for this as well?
thanks for your time
#219
Don't forget to reroute the crankcase vent tube from the inlet of the turbo to down by the frame. I just used 4 foot of 3/4 heater hose and a 1 inch plastic plug with original clamp to plug the hole.
#221
Help
I need some major help I have an 08 dodge 3500 6.7 I orderd a smarty jr. ME and a dpf delete pipes and a full egr delete I am confused on how to do the egr delete
I talked to someone and they said I need to leave something pugged in and just tie it out of the way so I don't throw any codes with the egr delete using a smarty jr
Please any help!
Please any help!
#222
On my 2011 I left the egr plugged in. The smarty took care of everyhing! The only thing I deleted under the hood was the throttle body. I know nothing about a 2008. Can you call the person you purchased it through? James at Rollinsmokediesel called me on the weekend to help me with my issiues.
#223
Please any help!
Please any help!
#224
GDP makes a delete kit for the doge 6.7 (air boss-67) and then they make a good intake manifold (mega flo S-2) and a flange (Mega flo throttle valve grid heater) and it gives you your grid heater back by moving it and giving more air flow. I am in Alberta too and this is the set I am going to be using so let you know what it is like in a week or so when all my parts so up.
