check engine codes
check engine codes
how do you clear the check engine light and clear the codes on the 3500 turbo diesel 2012,the exhast has been changed,and I get a mess,,see dealer the exhast filter is full,any help thanks
You can't remove the exhaust pressure sensors without throwing codes unless you are using a programmer/tuner. The only way to reset codes is with a code reader or a programmer that has that function.
madhat
68
10-25-2015 08:25 AM
exwrestler
02-05-2010 09:34 AM
sallyman1
08-26-2008 06:20 PM
alltimelow1
04-06-2005 07:28 PM
