2015 gauge pod suggestions?
Anyone have any suggestions for a 2 gauge pod for a 2015. I haven't looked too much, but haven't been able to find much. I don't really want to cut the grab handle off.
Thank - you for any input.
Thanks for the input. I ended up putting an Edge Insight CTS2 in. Edge doesn't make an adapter yet to mount on the pillar. I did a little improvising and bought Edges pillar mount and the CS adapter. Drilled a 15/16 hole in the CS adapter and used the end off the ball on the windshield mount to mount it through the 15/16 hole. Works great and looks like it was meant to be.
Sorry it took so long. I have been busy and keep forgetting to snap a few shots. 1st and 3rd pictures are the piece from the suction cup windshield mount you'll use. Pull them off the ball of the suction cup mount. The 2nd picture is of the $10 cs adapter. You'll need to drill a 15/16 hole in the approximate location that I did. Put the suction cup mount through the 15/16 hole and screw the nut snugly on the back.
I did much the same as above, just with an x monitor pillar mount. However, I am not too happy with this monitor. The right side, during the day, is shaded to the point of not being able to read it. I updated the unit with Fusion and now I no longer have TFT as a PID. That is one of the critical temps I like to see. I have contacted edge and as yet I have heard crickets in return.
mrhemi
Jan 13, 2015 11:37 AM
BrokeSolid
21
Feb 3, 2009 09:36 AM
Bad Ramer Jamer
Dec 1, 2005 02:30 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
