4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Temp Sensor
Old Jun 22, 2011 | 05:38 PM
Albertaguy's Avatar
Temp Sensor
My outside temp sensor appears to be stuck at 13 degrees Celsius. Does anyone know where the temp sensor is located on the truck which is a 2010 3500? I phoned my dealer and it was like talking to a brick wall.
Old Jun 22, 2011 | 05:53 PM
cbrahs's Avatar
here is the description from Chrysler
The ambient temperature sensor is a variable resistor mounted to the lower left side of the Front End Module (FEM), behind the radiator grille and in front of the engine compartment.
The ambient temperature sensor cannot be adjusted or repaired and, if inoperative or damaged, it must be replaced.
Old Jun 22, 2011 | 05:55 PM
cbrahs's Avatar
will have to remove the grille to get access to it. easy to remove grille. couple bolts and clips and its out. there are a couple plastic rivets that will need to be removed. they are not re-installable so you will need to get a couple more to re-install the grille. there are plastic push pins (reinstallable if you remove them without breaking them) and 4 bolts along the top
Old Jun 22, 2011 | 06:02 PM
New2Diesel's Avatar
"Gomer Pyle"
cbrahs, what is the FEM?
Old Jun 22, 2011 | 06:09 PM
cbrahs's Avatar
front end module. it controls misc stuff like washer pump, ambient air temp sensors etc.
Old Jun 22, 2011 | 06:28 PM
cbrahs's Avatar
ok, I'm playin.
they call the FEM (Front End Module (FEM) carrier (also known as the radiator closure)
since the truck is assembled in modules, they have designations for different sections of the truck similar to an airframe on a heli. (station # etc....)
Old Jun 22, 2011 | 06:44 PM
cbrahs's Avatar
check this PDF on page 6. it will show a pic of the dodge front end module
http://www.tradecommissioner.gc.ca/e...questid=769555
Old Jun 22, 2011 | 07:01 PM
Albertaguy's Avatar
Thanks everyone, I guess I will be taking it back. I hope the techs are smarter than the people I talked to.
Old Jun 22, 2011 | 07:15 PM
cbrahs's Avatar
there is a bulletin for the outside air temp being higher than actual when a snow plow is on but its one of those DUH things since the plow blocks airflow over the sensor and is getting heat soaked by the radiator.
its real and people have complained. fun to tell them nothings wrong lol
Old Jun 23, 2011 | 01:18 PM
Grand Geek's Avatar
If it was last week i would have said it was 13 outside lol
Tree DR
15
Mar 9, 2008 05:50 PM
Racing_Joe66
Jun 12, 2007 05:06 AM
jaconst
Jun 25, 2006 10:23 AM
turbox2
Feb 6, 2006 07:44 PM
firesine
Nov 24, 2005 10:58 AM
