4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Switched +12v Fuse That Stays Hot While Cranking?
Old Nov 18, 2016 | 12:17 PM
tobyw's Avatar
I'm looking for a different power source for my Mini-Maxx... the underhood fuse that I am currently piggybacked on is a switched 12V source as per the instructions, but the problem is that it always "short cycles" the programmer when I start the truck because I have to first wait for the grid heater, and then when you finally twist the key all the way to start the truck, it kills the circuit and the Mini-Maxx reboots again. This doesn't seem like a big deal, but about every 3 or 4 key cycles the darn thing looses the pyro source and reverts back to the factory source setting, so I have to fiddle with it to properly ready my EGT's... Just a PITA that I would love to figure out how to avoid? Yes I can get out my test light and check each fuse, but I figured someone has already solved the problem and figured I'd ask before wasting 20 minutes of my time... Thanks for any tips!!
Old Nov 18, 2016 | 04:27 PM
Busboy's Avatar
If you are having problems with the EGT it's probably about to fail, mine acted up to begin with then just quit. I ended up going with the H&S "universal" EGT and it's a much better set up than the original one, I also reused the original probe along with the new probe as it was still good.
rhader
Apr 26, 2011 11:12 AM
madhat
13
Jan 11, 2010 08:57 PM
53 willys
13
Jan 9, 2007 10:58 AM
Lightman
Dec 8, 2006 11:13 PM
