Question
Question
A little question for everyone i currently drive a 2010 Ram 3500 Heavy duty and has bank power system added.we are hauling 3 car trailer hauler my boss wants to move up to a 5 car trailer and keep the same truck and maybe do away with the dpf systemand add straight pipe and bullydog system and he still wants to get 500,000 miles out of the engine truck does do great as is but with bigger trailer and two more vehicles it will surely be to much for the current set up any comments would be appercaited
This is not intended as legal advice to be relied upon.
He may want to consider the liability issues with hauling that much weight. If your doing this for hire or commercial purposes, you are subject to license weight restrictions and not to mention having an accident while overloaded. I would suggest a 4500 or bigger vehicle designed for that type of work. If your the driver and know your overloaded, you have liability issues as well. The upgrade to a bigger vehicle would be much less expensive than the over load fines and possible legal liability involved, but I am risk adverse attorney. Good luck with the boss.
Can you give us the weights involved? I'm inclined to go with ljvsnyder and say "don't go there", but perhaps its not as bad as it sounds. More info is needed. Big difference with towing 24,000lbs and towing 30,000.
A 5 car rig is a huge setup...
You may need to step up to a medium duty truck.
info
ok to clear up somethings trucks towing compacity is 24000 pounds and trailer is 30000 pounds trailer does have well working trailer brakes both truck and trailer are dot approved so back to the basic question is what other mods. can we do to make the truck stronger but still last thanks for any info
Headstuds, Steed Speed Manifold, Larger turbine, Injectors, Lift Pump, CP3 increase %, and get rid of the factory intake and grid heater by installing a GDP intake and Air Boss.
If you do those mods, then your truck will be super strong. All you will have to do is cut an 8-10 thousand dollar check.
I wouldn't be too worried about doing the deletes and getting caught. Unless you're running CA. Even then you'd probably be ok with the stealth deletes. I don't remember hearing of anyone getting in any trouble by DOT or the law for running deleted. I definitely wouldn't straight pipe it, though, you'll need some sort of muffler on there. I guess there can always be a first.
I'd probably go with the H&S mini-max over bullydog, though. I don't hear of many using the bullydog on the various forums, so maybe they are OK, but the H&S is proven by many to be a good tuner with great customer service. H&S also offers trans tuning if you have an auto.
Now, a 5 car is LARGE and I don't think you're going to see anywhere near 500,000 miles out of a 3500 ram running with a loaded 5 car behind all the time. OK maybe you can make 500,000 out of it, but how many time you'll have to rebuild the truck to get it there is the question. Check out this thread from another forum:
http://www.cumminsforum.com/forum/6-...le-update.html
He's getting close to 500,000, but has had to replace/repair a lot of things to get where he is. He was running stock for quite a while, but did the deletes eventually.
I would think, it would make more sense to go with a larger class truck for a 5 car. You'll be saving money in the long run with fewer repairs and you have a much better safety margin.
Jeff.
Jeff.
mkeanglorldo56
Nov 4, 2007 12:34 PM
Murf
Aug 17, 2007 04:36 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
