4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Oil Change Indicator
Old May 13, 2015 | 11:10 PM
BobTipton's Avatar
On the oil change before the last one, I went 5,000 miles and the oil change indicator never sounded. Had it changed because of mileage. At that time, there would have been no reset on it required. Now, around 1500 miles after the most recent change, it sounded. What gives, and how do these things decide when the oil should be changed? Most miles (probably 75%) have been towing 14k fiver. Mostly idles while I'm getting the camper level and unhooked. Need that idle time for cool-down anyway.
Thanks,
Bob
Old May 16, 2015 | 09:42 AM
gsbrockman's Avatar
When I owned my 2007.5 RAM 3500 MegaCab, I always went through the re-set procedure even if I changed the oil prior to the system indicating I needed to do so.
It's designed to be re-set every oil change.
Old May 16, 2015 | 06:17 PM
BobTipton's Avatar
Thanks! Guess I'll just reset it and keep check on the level. If it makes too much oil I'll change it.
Bob
Old May 18, 2015 | 03:56 AM
Grit Dog's Avatar
If it's making oil you got bigger problems.
Just reset it when you change it. No big deal.
The oil life is calculated off of run time, engine load, idle hours etc.
I seriously doubt you could idle it enough to wet stack and make oil. Not cold enough and you'd plug the dpf.
To be honest with you, I don't think I've even pulled the dipstick on my 07 for 5 years. About every 8kmi I dump the oil/filter, fill er up again and reset the trip miles. Poor mans oil life indicator, lol!
Old May 18, 2015 | 10:12 AM
BobTipton's Avatar
Thanks, Grit Dog! I'll reset it and not worry.
Regards,
Bob
JARHEAD
Sep 28, 2011 09:37 AM
ctzdavis
Jan 2, 2011 01:54 PM
8bm
Aug 31, 2009 04:44 AM
MikeRP
17
Jun 12, 2008 07:48 PM
Dodgezilla
Mar 29, 2008 02:34 PM
