4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
68rfe transmission
Old Mar 26, 2023 | 10:54 PM
jd333d's Avatar
68rfe transmission
Hello everyone! I'm hoping to find somebody that can shed a little insight on a problem I've been having with this transmission. It's just being rebuilt with new valve body pump solenoid pack and all new clutches was working just fine when it started shifting strange and slipping in the lower gears . Po733 which is third gear slipping I didn't let it slip enough to hurt the clutches but for whatever reason it shows po868 code which is low line pressure I've changed the pressure sensor transducer the wiring looks fine could it be a computer issue? Anybody else that's had this problem would greatly appreciate any insight. thanks in advance!
Old Mar 27, 2023 | 03:00 PM
nothingbutdarts's Avatar
Is there a port to manually check line pressure to check it?
booman70
Aug 28, 2019 09:32 AM
APD
Jun 11, 2018 03:53 PM
mattym
Sep 21, 2010 09:02 AM
Agtech4020
Jan 15, 2010 04:40 PM
robinlh
Oct 25, 2006 11:04 PM
