Governer Sensor ... Solenoid ... or???
Old Oct 24, 2006 | 08:43 PM
robinlh's Avatar
I'm new here so please bear with me.
My 2001 dodge is having an intermittant issue where it will accelerate find up to about 45mph and then doesn't shift into the next gear. It will continue to accelerate but the rpms just keep getting higher (no where near the danger zone). If I pull over, kill the engine and restart, there's a 90% chance it will shift fine after.
I ran the codes and it's throwing 748 and 1762, one being a governer pressure solenoid circuit problem and the other being that the governer pressor sensor input was too high or low for 3 consecutive park/neutral calibrations.
Could the problem I am having be related to those codes? and if so ... what next.
Thanks in advance ... Robin
Old Oct 24, 2006 | 09:09 PM
paulb's Avatar
It sounds like it is the governer pressure sensor, but I would replace both the pressure sensor and the pressure solenoid. You can measure the pressure, and see if the pressure goes up when the trans goes into reverse, but this is a known problem on the 47RE trans. If it was me though, I would give DTT a call (866 504-4002). The have always been glad to help even when it's not one of their trans.
Hope this helps...
Paul
Old Oct 24, 2006 | 10:37 PM
robinlh's Avatar
Thanks Paul. One more question, where exactly is this governer pressure sensor (and solenoid) located? I have the Haynes book for my truck, but I'm not seeing anything about either.
Old Oct 25, 2006 | 02:36 PM
paulb's Avatar
They are attached to the governor body, inside of the trans, in front of the rear band lever, and next to the filter. The sensor is on the front side of the governor body cover, and the solenoid is in the center of the governor body cover. They are easy to replace. The transmission pan, filter, and governor body cover, are the only things that need to be removed. I prefer the ones from Dodge, instead of aftermarket ones... Once again though... Call DTT!
Paul
Old Oct 25, 2006 | 11:04 PM
shand101's Avatar
I had the same problem. rebooted the computer, codes and symptom both went away
MrHappy
Dec 9, 2005 11:23 PM
mcevins
May 20, 2005 07:53 PM
John H
May 28, 2004 11:47 AM
schu
Apr 21, 2004 12:39 PM
turbospl311
Nov 29, 2002 08:58 PM
