4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
2019 3500 HO with Aisin that has erratic shifting
Old Nov 14, 2023 | 12:24 PM
lenh22's Avatar
I have a 2019 3500 HO with Aisin that has erratic shifting. Under acceleration it will shift into neutral. , while in drive. All the gear shift indicators light up at this time. I can shift to neutral and back to drive and the transmission went back to working properly. I did have the trans fluid and filter changed. Does anyone known of a fix for this issue?
Old Nov 15, 2023 | 10:32 AM
FMB's Avatar
FMB
Did the shop use the special trans fluid or some generic stuff? If not, you WILL have issues. When I have my fluid changed, I go to the shop to make the appointment and tell them what tranny I have and what fluid it must have.
Check your Owner's Manual.
Back to morning brew . . .
Old Nov 18, 2023 | 10:15 PM
gsbrockman's Avatar
A few more details regarding current mileage and previous maintenance history would help. Did the shifting issue start AFTER the transmission service, or did it exist prior to servicing the transmission?
In any event….you have other issues going on if there’s illumination of all of the gear shift lights.
Old Nov 19, 2023 | 05:28 PM
lenh22's Avatar
shift to neutral
Thanks for your response. The truck has 145000 miles on it. It was doing the shift to neutral one time before trans. service. It does not do it on a regular basis. The shift indicators only come after after the shift to neutral. No codes come up. I used ATF +4 transmission fluid.
Old Nov 21, 2023 | 11:07 PM
Spooler's Avatar
I don't thank that is the right trans fluid. The 68rfe's use the ATF+4. The Aisin trans use a different fluid.
Old Nov 22, 2023 | 10:54 AM
lenh22's Avatar
Thanks, for the replay. Do you know what the fluid type is for the Aisin?
marvinmartian
0
Oct 18, 2020 01:05 PM
Green_Machine
0
Apr 8, 2019 11:06 AM
Jonesey
Mar 22, 2003 09:32 PM
alleyyooper
16
Nov 15, 2002 08:55 AM
