4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
17'ram 2500 6.7- error code P208b
Old Aug 2, 2025 | 05:03 AM
Frankdatank's Avatar
I got the 208p code and I took it to the shop and they suggested the shot gun approach, for 6 k. F that took it home to start replacing **** myself. So I got a new injector, no luck, I replaced the def pump and feed /heater line, dropped removed and cleaned out my tank and reseated all wiring harness connections on the def system. Re ran it today and my "def issue see dealer"message went away on my dash but CEL still on. I cleared the code manually and after driving it for about 30 miles I stiled the truck...ran into napa for something and when i stared it back up the same message popped back up with the 208b code.all that's left is the control module and pump wire harness....I don't have a fancy odb2 so ive been replacing parts slowly but **** this sux
I did have some other codes that haven't come back p2048 and p218f so I guess that's a small win
. thoughts?!
I did also disconnect the injector and turn on the truck and nothing is spraying. With a new pump I think I got a wire gremlin going on. 😔
v-kinger
Apr 6, 2014 06:10 PM
NWFarmboy17
Sep 21, 2012 05:42 PM
dieseldewlee
Mar 25, 2009 06:38 PM
gdafoe
Sep 23, 2008 09:50 PM
K2Cummins
13
Jan 22, 2008 08:55 AM
