4500 / 5500 - Chassis Cab Trucks Talk about your commercial trucks here. We realize there are differences with these compared to the regular pickups, so we have provided a place to discuss the commercial versions only.
No left hand turn lamp
Old Mar 5, 2010 | 06:49 PM
Diesel Boy 02's Avatar
Exclamation No left hand turn lamp
I have had a promblem before With what the local dodge dealer is calling a tipton meter, i belive, it watches your volts and if they drop, it cuts lights off, well I dont have any left turn lights on my bed, I still have the front working. I have been wondering is anyone out there, wiring around this, or making something to override this? I was also told I couldnt put LED's because it pulls to much juice and will short this box out.........
Old Mar 5, 2010 | 08:42 PM
Colo_River_Ram's Avatar
With age comes the cage
That's an interesting story on the LED's... LED'S draws less amps than the stock lamps do. if you get a fast/no flash it can be attributed to the LED's low amp rating.. generally speaking you want a min of 2 and max of 4 amps on your TS / tail light circuits.. When I put my Optronic LED's on my bed I was in the range on the tail light circuit but had to install the "RL650" 6 Ohm, 50 Watt load resistor on the TS circuits to prevent the fast flash.. You will get a lamp out indicator if your tail light circuits do not have a big enough load as well..
Here is the link to the "RL650" load resistors, about halfway down on the page / the one under it is for the tail light circuit:
http://www.superbrightleds.com/cgi-b...gi?product=CAR
Here is a link to the Dodge up-fitters site for more info on this subject:
http://www.dodge.com/bodybuilder/year.pdf
You need to go to your light mfr's site and get the ampacity rating of the lights and work from there..
Old Mar 5, 2010 | 08:46 PM
Thanks, thats what the dealership told me when I bought my truck. I was always told LED's pulled less juice. Thanks for the info. If now I can just get my turn sig. back on........
Old Mar 5, 2010 | 08:53 PM
Yeah I've had to bring my dealer "Up To Speed" on a few items as well..
Try putting a test light in the LT circuit and see if that helps..
Old Mar 5, 2010 | 08:57 PM
I have pulled my wireing apart where we put the bed on, and I have no juice on the truck side of the wiring, just for kicks, I had the park lights on and jumped them to the LT wire, and the lights came on. So I know its something on the truck side.......
Old Mar 5, 2010 | 09:01 PM
Sounds like you problem is in your TIPM..they have a flash to fix this..
Search this site for it..there has been a lot of posts on it..
Is the truck throwing any codes?
Old Mar 5, 2010 | 09:04 PM
Dealer told me they need to reflash it, but said it might last for alittle while..... this has only happend 2 times, this last time I pulled a old trailer and I guess it triped it. I cant tell, I have my dpf and egr off the truck. Is there anyway to go around it?
Old Mar 5, 2010 | 09:15 PM
The flash should increase the rating on the TS circuits.. I understand the old trailer delima..You could install one of these into the trailer light circuit as it pulls juice from the battery and not off the truck harness:
http://www.etrailer.com/p-119190KIT.html
Ive thought about installing a HD modulite into my tow circuit as well..
Here's my beast, starts at post 22:
https://www.dieseltruckresource.com/...t213006p2.html
Old Mar 5, 2010 | 10:37 PM
so the short of this story is, there really isnt a dang thing I can do to get the lights back on. untill I take it back to the dealer?
The thing about it is, my trailer plugs still work fine. Its just my bed lights.
Thanks Colo_River_Ram, thats a sharp truck. Im going to install one of those boxes so I can put LEDs on my bed.
I just wish this thing was like my 2 gen trucks...........
Old Mar 5, 2010 | 11:09 PM
PM sent DB2
Hoss
21
Dec 3, 2016 02:49 PM
relay93
Jun 22, 2006 05:19 PM
darrenG
Oct 5, 2005 11:12 PM
Pickle
Mar 26, 2005 11:57 PM
