4500 / 5500 - Chassis Cab Trucks Talk about your commercial trucks here. We realize there are differences with these compared to the regular pickups, so we have provided a place to discuss the commercial versions only.
Flat Bed Is Done..
Old Aug 2, 2008 | 10:02 PM
Colo_River_Ram's Avatar
With age comes the cage
Flat Bed Is Done..
Weighing in at 11,000 lbs..
Old Aug 2, 2008 | 10:19 PM
Machinos's Avatar
Just the truck and the flatbed weigh 11k?
Old Aug 2, 2008 | 10:52 PM
Yes C&C truck about 8.600lb + 2,400lb bed = 11,000lb
Old Aug 3, 2008 | 01:09 AM
catnfool's Avatar
you forgot your mesh in the back window- unless you wanted a slider anyways!!!! Nice work by the way; I moonlighted for a fab shop in town and appreciate your fenders
Old Aug 3, 2008 | 12:20 PM
Thanks Cat.
Actually the mesh as you call will be a CNC plasma cut design, It will be a bolt on in case if the rear window is broken and needs replaced (don't want to pull a bed to replace the glass) .. same goes with the LP as well, the trap door that gives you access to the truck/trailer electrical is located on top of the LP
Old Aug 3, 2008 | 04:43 PM
chaikwa's Avatar
That is one nice, NICE body! I build truck bodies and trailers for a living and I KNOW how much work went into that. You certainly pay attention to detail!
chaikwa.
Old Aug 4, 2008 | 01:37 AM
Here is a couple of pics of one of the trailers(built it too) I pull with the truck
Old Aug 4, 2008 | 01:42 AM
catnfool's Avatar
OK, then it passes with FLYING colors then The last one we built was all aluminum for a dually- turns out this new calcium cloride(ice melt) they put on our roads doesn't like AL much We had to rip it off and paint it; whats the fun of having AL if it doesn't look like it
I really like your boxes- and a person REALLY shouldn't HAVE to plan the "next" LP failure DODGE, are you listening
Old Aug 4, 2008 | 02:47 AM
Tedonlin150's Avatar
So what do you haul on that huge trailer? Oh and very nice truck by the way
Old Aug 5, 2008 | 09:27 PM
RobG's Avatar
NICE flatbed!!!
Question... what's the spacing from the top of your tires to the underside of the deck? I'm still trying to figure that out for the deck I want to build...
Rob
Old Aug 5, 2008 | 10:02 PM
Rob,
here is the link to the C&C upfitters guide, if your a standard cab w/bed you could probably still use some of the data... the bottom of my bed is 9" above the frame..that is max tire travel listed in a crab situation according to the dimensions / Views and chart section..
http://www.dodge.com/bodybuilder/2008/dm/dmmo.pdf
Old Aug 6, 2008 | 04:33 AM
6cylinders's Avatar
Very nice work! Like the color choice, it shows off the workmanship much better than black would.
Old Aug 6, 2008 | 10:44 AM
Thanks 6-C
Ted it is used to haul tubing to and from the oil/gas locations I work on..
Old Aug 10, 2008 | 11:25 AM
rfeiller's Avatar
how did you attached the bed to the frame, with the restrictions by dodge of drilling or welding top and bottom flanges? very attractive bed.
Old Aug 10, 2008 | 03:45 PM
I used all existing holes, the upfitters guide gives you the specifics on what you can or can not do.. When I get some extra time I'll post a slide show of the project.
