4500 / 5500 - Chassis Cab Trucks Talk about your commercial trucks here. We realize there are differences with these compared to the regular pickups, so we have provided a place to discuss the commercial versions only.
2008 4500 Fuel Tank Vent
Old Jul 27, 2012 | 10:14 AM
CoastalDav's Avatar
I have a friend that is a fulltimer, with a 2008 4500 that continually has problems when filling the fuel tank. It spits and burps not allowing him to get it full. I looked at all the TSB's and searched this forum without any luck. One TSB talked about debris getting into the vent causing poor performance. Nothing specific when fueling.
Has anyone else had this problem? Fixes?
Thanks in Advance
Dave
Old Jul 27, 2012 | 11:52 AM
Colo_River_Ram's Avatar
With age comes the cage
The only problem I have filling mine is that "Green-Armed-Bandit" keeps robbing me. I fill from the back though a 90 as well..
Do a search for "vent mod"
Old Jul 27, 2012 | 12:09 PM
CoastalDav's Avatar
Thanks for the info. Your post was the only thing that showed up in the forum search. Figures.
Dave
Old Jul 27, 2012 | 12:22 PM
Try putting a "Tank" in front of the vent mod, there is several good threads on the subject. What kind of bed does he have on it? the only thing I can think of is they pinched the fill or vent hose on the install.
Old Jul 27, 2012 | 12:27 PM
CoastalDav's Avatar
Can't find any threads of the Vent Mod. He has a hauler bed on the truck.
I just told him to get under the truck and look. He's not very mechanically inclined and has a bad back.
If you know where those threads are, I would appriciate a link.
Thanks
Dave
Old Jul 27, 2012 | 04:45 PM
Here is a PDF from Glacier Diesel on their kit for the standard truck, it should be similar for the C&C (call them to verify):
http://www.dieseltruckresource.com/d...2&d=1299097819
The C&C came with a bag that had a couple of hoses for fill options, this is the one(stock 90) that I used:
Note:
The vent hose was longer than needed so it could be cut to size on final install.(this might be where the problem is)
The wire is the fill spout ground wire.
Go to post 22 here and click on the small photo for a slide show of the bed build, towards the end of the show is the hose hookup:
https://www.dieseltruckresource.com/...t213006p2.html
Old Jul 28, 2012 | 11:21 AM
CoastalDav's Avatar
Thanks for the info. That was a good slide show if for nothing else on how to build a bed. The one picture of tank top and its connections, may or may not help my friend. I sent the thread to him last night. Have not heard anything yet.
Thanks again!
Dave
Old Jul 28, 2012 | 11:46 AM
Your Welcome,
Ill bet you a quarter they did not trim the vent hose or they crimped it during the installation.
Old Aug 12, 2012 | 10:41 AM
Any update on this?
Old Aug 12, 2012 | 11:02 AM
CoastalDav's Avatar
The owner of the 2008 4500 looked at the fill hose and indicated it had a dip in it to clear the bed. I told him that was most likely why he's having problems fueling.
He has not replied any further to date. Will check it out and see what going on.
Dave
Old Aug 13, 2012 | 08:22 AM
RamGazer's Avatar
10 Year Member
Check out this post. This might be what your friend is looking for. Scroll down to post #5. Good luck.
https://www.dieseltruckresource.com/...k-t299151.html
Old Aug 14, 2012 | 04:15 PM
CoastalDav's Avatar
I got an email from the owner of the 4500. Here is want he had to say;
"I've started putting two orange levelers under the side of truck accepting diesel. This makes some elevation down to the fuel tank. Last fill up guy next to me said they carry a two by six on there flat bed to help when filling there trucks. Had a guy who owned tow trucks say the same thing. Another guy said they fed gas into another hose (farm trucks) which allowed more drop into tank. Sounds like this is a common issue with flatbed or western hauler bodies. It must be an issue with elevation or not having enough drop between entry point and fuel tank. It feels strange putting blocks under tires and sometimes that doesn't seem to help."
He's currently headed to Rapid City after visiting Devil's Tower.
Don't know if he plans on doing anything else with the vent or fill hose.
Dave
Old Aug 14, 2012 | 07:51 PM
Dave,
Thanks for the colorful update..
It must be the western bed as mine fills with no problem even with the big pumps at the RV stalls.
I guess I owe you a quarter
Guardrail
Mar 6, 2007 04:42 PM
mt72916
24
Mar 2, 2007 08:36 AM
grantx5
Feb 13, 2007 07:11 PM
justcampin
Feb 9, 2007 08:44 PM
v8440
Apr 10, 2006 04:05 PM
