2008 4500/5500
Old Feb 24, 2007 | 10:39 PM
mt72916's Avatar
Talking 2008 4500/5500
didnt know where to post this info that i just found. thought i would pass it on
http://www.dodge.com/dodge_life/news...assis_cab.html
mel
Old Feb 25, 2007 | 12:29 PM
Luvnacumns's Avatar
52 gallon tank!!!!! He#$ Yeah!!! I want one!!
Shane
Old Feb 25, 2007 | 09:09 PM
98.5POS's Avatar
From what I've read on the 4500/5500, the only difference between them and my C&C 3500 is the weight raitings - which I'm sure means bigger axles and springs. The brakes on my 3500 are the same ones in that advertisement. And mine also has the 52 gallon tank. When I heard they were coming out I was not happy that I bought mine, but after some research I'm glad.
Let me say this - I drove my brother-in-laws 2007 Duramax C&C this weekend and was not impressed! The engine felt a lot racier than mine, and the truck felt lighter, but the brakes and handling couldn't compare to my C&C! So far I'm very pleased with it.
Old Feb 25, 2007 | 09:32 PM
06dually's Avatar
another difference is 19.5 inch 10 bolt wheels...I bet you have some range with that tank though.
Old Feb 25, 2007 | 10:25 PM
kawiram's Avatar
are those the same axles as the light duty trucks? Hope not.
Old Feb 26, 2007 | 01:51 AM
Road Traveler's Avatar
Heck yeah on fuel range! plus with the C&C you can get a 22gal (I think or 24gal) midship tank as well from dodge! Then put on a 100gal aux. tank and you would be set!!
Old Feb 26, 2007 | 05:40 PM
Luke S's Avatar
You can't get the 52 gallon aft axle tank in conjuction with the 22 gallon midship tank, only one or the other.
Old Feb 26, 2007 | 05:41 PM
Luke S's Avatar
No, they are heavier.
Old Feb 26, 2007 | 10:26 PM
C&C Milo's Avatar
The 3500 has smaller brakes than the 4500/5500
Go to http://www.dodge.com/en/chassis_cab/...apability.html
and click on brakes. 3500 is 352.3mm, 4500/5500 is 390mm
Old Feb 26, 2007 | 10:39 PM
torquefan's Avatar
Has anyone heard what axles the 4500 and 5500 come with?
Old Feb 27, 2007 | 11:24 AM
bigblock2stroke's Avatar
Dana's I think
Old Feb 27, 2007 | 11:52 AM
scook6's Avatar
110 Dana in the rear, and the front pumpkin is a Magna unit.
Old Feb 27, 2007 | 10:29 PM
torquefan's Avatar
Dana 110. I don't think that's as big as the one in the F550.
Old Feb 27, 2007 | 10:33 PM
GOTMEAT's Avatar
From what I have read, the 450 has a 110 in the rear and the 550 has a 135?
What boggles me though is the increased tow ratings on these things over the 3500's and 2500's. I understand the payload difference, that's a no-brainer. But with the same motor and tranny, how do they increase the rating by changing the gear ratio? I think the 550 carries a GCW of 33,000. You can't tell me that that truck is going to move 33,000 as well as we can move 23,000.
Old Feb 28, 2007 | 10:46 AM
jkitterman's Avatar
If you are comparing the Ford 550, you should use the Dodge 5500's rating of 26,000 GCWR. I do think it is funny that Ford has that rating where I would think they would just steer someone to a larger 650 or 750 for over 26,000.
