Windshield Washer Nozzle Clogged
Old Feb 13, 2011 | 08:27 PM
dd5087's Avatar
Anyone have a good method to clear a clogged windshield wiper nozzle? I have one of them that barely puts out any fluid. Thanks
Old Feb 13, 2011 | 08:52 PM
gcssr's Avatar
use a needle, works for me
Old Feb 13, 2011 | 11:21 PM
AkTallPaul's Avatar
air gun...give a quick swipe or blast...
Old Feb 14, 2011 | 11:32 AM
1-2-3's Avatar
Just a plain ole guy
I used to have an issue with mine getting clogged by fire ants. haven;t had it with the 04, but on the 99, I pulled the hose off and held on to the front of the nozzle and let the pump and juice push the ants out the other way. If you don't remove the hose, your just pushing whats clogging it back down the line and it will clog again.
Old Feb 14, 2011 | 12:48 PM
madhat's Avatar
Administrator/Jarhead
I had that problem on my wife's truck, I ended up taking it out and blowing air through it, worked like a champ. You have to take the wiper arms off (very easy, lift the metal tab at the base of the arm, pull wiper straight up) and take the plastic cowling off to get to it. Not hard, if you need help, PM me.
Old Feb 14, 2011 | 05:06 PM
dd5087's Avatar
Soon as I have the time, I am going to try the needle first, if that doesn't do it, then I will try the air. If neither of these fix it, then I will do what madhat suggested. Thanks for all the replies.
Old Feb 15, 2011 | 12:18 AM
.boB's Avatar
Take it off. Soak it for a while in Lime Away. Then blow it out with air
06RAMCTD
Nov 28, 2009 07:57 AM
Vinceg99
21
Feb 11, 2007 10:06 PM
Larry R
Apr 24, 2006 08:42 AM
ptm600
Jan 31, 2006 07:43 PM
Igor
Nov 15, 2005 03:04 PM
