Whistle while you heat
Old Dec 7, 2008 | 12:30 AM
Holycack's Avatar
My cab seems to pressure up when the heater is turned on and taking in fresh air, it whistles very loudly out the drivers window. If I crack a window the whistle goes away, it also goes away if I put the heater on recirc. Could my cab vents be stuck closed? Any ideas as to what the problem is? Thanks
Old Dec 7, 2008 | 01:35 AM
Highway 4x4's Avatar
Yep, that's what they do.
Old Dec 7, 2008 | 08:25 AM
mikmaze's Avatar
your door could be tweaked also, amazing how easy you can flex the top corner of the door and get it to align moulding to cab, or in your case, it seperrates and then you hear the noise. look for signs of the seal not touching the cab, and flex the door do see if you can get them together and doing their job.
Old Dec 7, 2008 | 10:06 AM
rockcrawler304's Avatar
I would check the cab vents. I have 2 good sized ones behind the rear seat. As long as yours are able to open you should never need to crack the window to stop the whistle.
tswcoaltrain
Nov 12, 2019 09:11 PM
bkrukow
Apr 29, 2011 06:42 PM
PChouinard
Jan 27, 2009 05:46 PM
jrs_dodge_diesel
Dec 20, 2005 09:56 PM
nonford
Aug 1, 2004 12:28 AM
