Whinches
Old Oct 19, 2009 | 10:34 PM
bansh-eman's Avatar
Whinches
What is a good winch to put on our trucks that isn't going to murder my bank account? I Don't want anything fancy, just something that will not break all the time and doesn't cost a fortune.
Old Oct 19, 2009 | 11:17 PM
Totallyrad's Avatar
I believe there was an 8k Warn in the classifieds last week.
Old Oct 19, 2009 | 11:45 PM
bansh-eman's Avatar
Any feedback on Recon winches?
Old Oct 19, 2009 | 11:54 PM
cLAYH's Avatar
A used Warn winch is usually a better deal than most of the cheapie ones new and will last longer. Check your local cgraigslist and Kijji.
Be advised that a PROPER mounting system for it often costs more than the winch.
Old Oct 20, 2009 | 03:20 AM
TexasCTD's Avatar
I've got an electric MileMarker 12K winch on mine. I haven't used it much but it has worked fine the few times I have used it. Probably about as cheap as you can buy a winch.........for it's size.
And I suggest you get AT LEAST a 12K winch. More if you can afford it. I hear a good rule of thumb is 1.5 times the weight of your vehicle....so an 8K winch is to light for our trucks........if that is true.
Old Oct 20, 2009 | 06:29 AM
bansh-eman's Avatar
1.5 sounds reasonable. If it has to pull all the weight out of something that the truck can't get it's self out of, then I can see where the additional 50% of the weight rating would be a safe bet.
As far as a "porper" mounting setup. I am not that worried about it. I will not be doing rock crawling or anything that the winch will be used in dangerouse situations much. I am getting it for the chance that I get buried at the deerlease.
Old Oct 20, 2009 | 07:08 AM
FrozenAssets's Avatar
Exclamation Danger = Danger
Doesn't matter if you are rockcrawling or stuck in a mudhole at the deer lease. The "danger" factor is EXACTLY the same. If something comes loose under load, you (or any bystanders) could be killed. The winch must have a mounting plate that is frame anchored, and that will cost a few hundred bucks. It's just a cost of having and using a winch (just like using the proper gauge wire to get enough juice to the winch).
Old Oct 20, 2009 | 07:10 AM
Totallyrad's Avatar
So you're recommending a single line pull of 1.5 times the truck weight? The reason I ask is adding a single ****** block will give an 8k winch a 12k pull. The only drawback is the reduction in line length.
Old Oct 20, 2009 | 07:19 AM
bansh-eman's Avatar
I am talking about loosing a truck that goes tumbling down a hill becasue the winch gave out. Getting stuck in the mud at the deerleas isnt nearly a dangerouse as trying to pull a truck up out of some big rocks.
Why do they need to be mounted to the frame? I see jeeps all the time with them mounted to the bumpers.
Old Oct 20, 2009 | 07:33 AM
CTD NUT's Avatar
****** blocks can only take you so far....and they have limitations of their own, too.
The 1.5 times gross vehicle weight thing is a general rule of thumb. You must remember that the 8K winch rating is on the first wrap of cable on the drum and just before the point of the winch motor stalling - in other words, the absolute max load the winch can pull. Every additional wrap of cable on the drum is worth another 12% reduction in pulling power. An electric winch has a very short duty cycle when running at max load should not be used frequently in that condition. If the winch is used frequntly at max load, you have the wrong winch for the application.
There really isn't any way around the fact that a truck weighing around 8000 LBS or close to it, really should have a 12K winch. Demanding winching with an 8K truck would not preclude the use of a 15-16.5K winch, either. The 1.5 times GW is just a general guide - more demanding conditions may dictate the need for a stronger winch.
Old Oct 20, 2009 | 07:42 AM
CTD NUT's Avatar
The winch has to be mounted directly to the frame no ifs, ands or buts! Jeeps have many winch bumpers available for them that are very sturdy and intended to accomodate a winch that in turn does bolt directly to the frame. You can get similar winch mount bumpers for your Dodge. Also, several jeep models have a winch mounting plate available that sits right over top of the OEM bumper that may make it appear as though the winch is mounted to the factory bumper, but I assure you it is not.
Old Oct 20, 2009 | 07:52 AM
bansh-eman's Avatar
Yea I know the bumpers are mounted to the frame and have the winch mounted to the plate on the bumper. I was planning on buying a Ranchhand that is configured just like that. He made it sound like you have to mount it directly to the frame and not to the bumper mount on the after market bumpers.
Old Oct 20, 2009 | 08:08 AM
dieselfumes57's Avatar
i have a warn 9.5 that has been been abused for 5 years and still works great.
When i say abused i mean abused......look on ebay.
Old Oct 20, 2009 | 08:16 AM
Totallyrad's Avatar
I was just over at the Warn site and it looked like they were having a sale. Since I was just there I'll add a little more info here, remember Warn also offers a hybrid. That means you get a winch and air compressor in one. They also have a kick butt stand alone 12v compressor now.
Power: 12V DC motor
Maximum Pressure Rating: 125 PSI (862 kPA)
Airflow Rating: 20 CFM @ 0 PSI; 8 CFM @ 90 PSI; (566 l\min @ 0 kPA, 226 l/min @ 620 kPA)
Intercooler/Air Reservoir Size: 1 gallon (3,78 liter)
Old Oct 20, 2009 | 12:24 PM
TexasCTD's Avatar
Rick I think he answered it better than I could right here....below. I honestly don't know alot about winches...but I knew 1.5 x truck weight was a general rule.
