Where to get Oil Filter
Old Nov 9, 2004 | 04:26 PM
Mark Hodowanec's Avatar
Where can I get a Fleetguard filter? I rather not get ripped off by the Dodge dealer. I am in the Sterling VA area & would need to change my oil this week!
Also, what is the part number for this filter?
Old Nov 9, 2004 | 04:45 PM
converteddzlr's Avatar
Check out your local Cummins shop. They stock them and are much cheaper than the DC gang!
Old Nov 9, 2004 | 04:49 PM
firestorm's Avatar
Genosgarage.com is where I get mine.
Old Nov 9, 2004 | 05:02 PM
bhoeffner's Avatar
Get mine from Cummins.
Old Nov 9, 2004 | 05:44 PM
tmgxray's Avatar
I get mine from a local freightliner shop for $6.28 (fleetguard). U could also try other big rig shops, they might be able to get them also. Hope that helps
Old Nov 9, 2004 | 06:28 PM
chrismez's Avatar
Ebay has a case of Chrysler OEM filters for $72.00
Old Nov 9, 2004 | 09:02 PM
Geico266's Avatar
Any local Cummins repair shop. Just follow a big rig!
Old Nov 10, 2004 | 06:56 AM
rws's Avatar
rws
Would a Napa parts store have them? Seems like Napa has a cross reference filter for everything.
Old Nov 10, 2004 | 07:12 AM
Blue600's Avatar
I got the LF 16035 Stratapore filter at my local Cummins shop for $12.
Old Nov 10, 2004 | 02:33 PM
1sttruck's Avatar
When buying the filters from Cummins be sure to get the fluted type, at least if you use one of the end cap filter wrenches. As I was installing one of mine I noticed that wasn't fluted, sighed, and then finished tightening it.
Old Nov 10, 2004 | 04:35 PM
CTDinMT's Avatar
Make sure next time you get a Fleetguard LF16035, its the Stratapore and I haven't ever seen one that wasn't fluted on the bottom. -Steve
Old Nov 10, 2004 | 07:37 PM
1sttruck's Avatar
I have, and it's on my truck :^)
Old Nov 10, 2004 | 08:33 PM
Dr. Evil's Avatar
NO - NAPA will not carry a Fleetguard. The cross reference means nothing - it wont be a Fleetugard and will NOT be an approved filter.
Old Nov 11, 2004 | 10:54 AM
rws's Avatar
rws
OK, I'm not trying to argue here, but to say that any other filter than a Fleetguard is not an approved filter? I did a quick search on Fram and Wix sites and they both have a cross reference filter.
I am sure truckers will buy a filter wherever they are when the time comes, and not worry if it's not a Fleetguard.
In the heavy equipment world, not many companies buy Cat filters all the time for their equipment.
I can see the need to be careful in the grade/weight of oil used to maintain a warranty. But a specific filter is something I've never seen in print.
Am I completely wrong?
Old Nov 11, 2004 | 11:43 AM
RamDan03's Avatar
There are other filters that you can use, but the preferred filters are Fleetguard due to the excellent quality, low price, and wide availability. Here is a link to some of the approved filters for the Cummins engine:
http://dodgeram.info/tsb/2001/09-004-01.htm
NEVER use a FRAM filter on a Cummins engine. If the engine fails while running a FRAM filter, your warranty will almost always be voided because they are not approved filters.
