Welding on Side steps?
Old Apr 4, 2008 | 10:22 PM
woodrep's Avatar
I have found a nice set of custom built sidesteps that were made for a longbed and intended for bolt on mounting, but my truck is a short bed and the tank is in the way for passing a drill or bolt through. Here's the dilema, I would simply like to weld on the bar plates to the sides of the frame. Any negatives to doing this? I have searched many of the old posts and in my own conclusions find that it is in fact O.K. to weld onto the frame. Anybody have a similar experience to this? TIA
Wood
Old Apr 5, 2008 | 09:50 AM
johnh's Avatar
as long as you don't weld on the flange of the frame you will be ok, but i personally would use self tapping bolts, you can drill thru the side of the frame without coming close to the tank.... the flange is 3 or 4 inches wide
Old Apr 5, 2008 | 10:03 AM
neveragain's Avatar
mounting running boards
I had the same problem with my long bed. What I did was to bolt (clamp) to the top and bottom of both sides of the fuel tank and run a flat bar across the bottom of the frame and a ??? vertical piece of 3/4" drilled and tapped to hold the bottom of the bracket for the running board. Solid as a rock. They use it to pickup the truck when it needs it. I don't remember what I used for a spacer for the offset but a 3" or 4 " what ever it is piece of tube steel 2"x3" vertical will bolt it solid to the frame. If I knew how to use the plugin stuff for the camera I would send you a picture of it. Would have to get girlfriend to do that for me. Does anyone else have problems with computors like me?
Old Apr 5, 2008 | 02:11 PM
tankn60's Avatar
I had some welded on last summer on a 07, just disconnected both neg battery cables, don't see anything wrong with weld ons.
Old Apr 5, 2008 | 02:41 PM
Dieselnick's Avatar
Ya, definitely disconnect the batteries before you weld.
Nick
Buckshotmckee
28
Feb 7, 2007 05:55 AM
onemorodeo
Apr 16, 2006 10:37 PM
onemorodeo
Feb 4, 2006 06:43 PM
surlynkid
Dec 30, 2004 08:10 PM
Buff1147
Apr 13, 2004 09:34 AM
