Weight of SRW3500
Old Nov 14, 2004 | 04:15 AM
Hedgehog's Avatar
Weight of SRW3500
I am debating on whether or not I need a dually so I was trying to figure out what the payload capacity would be on a 3500SRW, quadcab, 4X4, diesel. I tow a 5th wheel with a pin weight of approx. 2200lbs. but only tow it 1500 miles a year so if the SRW can handle it legally, it might be better. Especially because in Mass., anything over 10,000GVW requires commercial plates so that's $180/year vs. $40/2years.
Old Nov 14, 2004 | 05:26 AM
JohnnyH's Avatar
When I picked up my fifth wheel I stopped by a CAT Scale. I was the only one in the truck, full tank of fuel and no camping supplies since I was just picking it up. My results were 4600 steer axle, 4600 drive axle, and 6760 trailer for a total of 15960. That put me 700 lbs under GVW and 5040 lbs under GCWR.
A few weeks later I reweighed it with the family and gear. It was Me, my wife and 2 children. Also, Firewood, BBQ, Shovel, bicycles, most of the things you would probably bring with you. I only had 1/2 tank of fuel on this weigh. 4900 steer axle, 5160 drive axle, and 7220 trailer for a total f 17280. That put me 160 lbs over GVW and 3720 lbs under GCWR.
A few things about this. On a SRW, you can run out of payload pretty quickly with only a 9900 lb GVWR. Next time, I will load the truck slightly diffrent to move some weight to the trailer and bring me back within limits. I also have a set of running boards that weigh a little over 200 lbs, so that dosent help. My 5'er isnt very heavy. It probably weighs about 8000 lbs empty so use that as a judge for what the pin weight is.
2200 lbs will most likely put you well over 9900 lb GVW, by the time you put a hich, people and supplies in the truck.
Hope this helps.
Old Nov 14, 2004 | 03:11 PM
SuperGewl's Avatar
Here you go SRW SB data:
Truck
Steer 4320
Drive 3220
Gross 7540
This is with the truck loaded with fuel and other normal stuff in it for travel.
My 5VR weight is:
GAWR 10160
GVWR 11437
UVW 7795
CCC 3114
Hitch 1277
Truck & 5VR actual weight per scale:
Steer 4300
Drive 4620 (Hitch 1400)
Trailer 7480
Gross 16400
5VR had full 50gals potable, LP tanks full, various junk you would normally carry.
From what you said You may need to get the Dually.
My truck has a payload of 3k per DC.
Old Nov 14, 2004 | 09:00 PM
StrokeThisCTD's Avatar
use this, it helps a lot with deciding a truck
http://www.dodge.com/towing/D/home.html
Old Nov 15, 2004 | 10:23 AM
Bertram65's Avatar
My truck is about 7400 lbs with the 5th wheel hitch in, I weighted it at the CAT scales off of 95 in NH, it was about 7200 lbs without the hitch. Where in MA are you? I am in Lynnfield, you don't see too many other members in MA.
Old Nov 16, 2004 | 10:56 AM
steved's Avatar
Mine is a standard cab 2500, but it weighs 6850...they print it right on the registration.
It shouldn't matter what the truck weighs, they go by GVW determined by the manufacturer usually. My 2500 is rated at 9,000 pounds GVW which put me into the $153 a year range.
steved
Old Nov 17, 2004 | 09:24 AM
by2005's Avatar
weight of srw3500
I towed and weighed last weekend. My 2003srw 4wd long quad was towing our 38' 5er. ...
truck f 4575
truck r 3175
hitched r 5950
5er 10,425
pin 2775
total 5er 13,200
total combo 20,950
That make sense??
John Marshe
Aug 14, 2020 09:00 PM
Purplezr2
Jul 25, 2011 04:31 PM
Hedgehog
Nov 15, 2004 09:46 AM
j28s
May 25, 2003 11:13 PM
COHUTTA MNT KID
Oct 12, 2002 08:17 PM
