Voltage Problem need Input
Old Feb 23, 2006 | 09:35 PM
DBHMEH's Avatar
Hi,
I'm new here and all ready need help. I picked up mu 06 Ram 2500 4 days ago havent started it for 2 days. This evening I started it and the voltage went up to 15-16 and then I hear a click and the voltage dropped to 12.5-13 the click back up to 15-16. The Lights dim and get bright each time. This cycled several times and then stopped. It remains charging at 15-16. It did occur with engine off initially while in vehicle with interior light on. Noticed the dim/bright. Any direction is appreciated.
Thanks
David
Old Feb 23, 2006 | 09:40 PM
donhov's Avatar
This is a normal occurance. It is caused by the grid heaters cycling off and on causing a large voltage draw. Usually happens after the truck has sat for a while or it is very cold outside.
Totally normal.
Old Feb 23, 2006 | 10:03 PM
DBHMEH's Avatar
Thanks!
David
Old Feb 24, 2006 | 04:36 AM
rammtuff's Avatar
Totally normal.
This information might also be in the owners manual
Old Feb 24, 2006 | 08:36 AM
dhe9's Avatar
Totally normal.
hello,
i understand about the grid heaters. my question is that my truck seems to charge at about 15-16 amps. this seems high, no? i thought the normal was about 14 amps. the manual states that if the voltage is too high a chime will sound. have not had any chimes. just seems 15-16 is high.
what do you think?
david
socal
Old Feb 24, 2006 | 08:54 AM
jkitterman's Avatar
The guage reads in volt, not amps. The charging voltage is dependant on battery temp but that is within the normal range.
Old Feb 24, 2006 | 09:57 AM
dhe9's Avatar
sorry, ment to say volts. hell, if the alt was only putting out 16 amps i think my truck would be in trouble.
good to hear tht the 15-16 volts is okay.
socal
imbodie
21
Jan 8, 2024 08:49 AM
sahbahdoo
Jul 5, 2008 11:08 AM
Joe Diesel
Nov 12, 2007 08:59 AM
deereguy07
Sep 17, 2007 08:08 PM
rattle_rattle
14
Oct 16, 2002 07:05 PM
