Vin Decode
Old Mar 19, 2007 | 11:43 AM
CTD8939's Avatar
Vin Decode
Could somebody tell me specifically what I have here according to the vin. Thanks
VIN# 3D7KS28C55G748507
Thanks
Old Mar 19, 2007 | 12:20 PM
Tmc243's Avatar
It's a Dodge Truck . What did you want to know about it?
Old Mar 19, 2007 | 01:01 PM
BigDave12768's Avatar
Its a 325hp 610hp Cummins
Old Mar 19, 2007 | 01:41 PM
CTD8939's Avatar
That I know. What I am unsure of is the 3:73 axle ratio, whether or not it has the tow pkg, snow plow prep, etc. etc. etc......
Old Mar 19, 2007 | 02:13 PM
annabelle's Avatar
If you have an 05 auto then they are 3.73 gears I believe. About 70 MPH @ 2000 RPM.
Old Mar 19, 2007 | 02:32 PM
Tmc243's Avatar
It does have 3.73 gears, has tow package, heavy duty snow plow prep group,anti-spin rear axle. What else would you like to know? I can't figure out how to transfer all the options on to here or I would just list them all.
ID2500Ram's Avatar
The VIN does not contain the rear end ratio or other options. Have to look at the sticker in the glove box for ratio. Go here and fill out the form and they will email you the build sheet with all options.
http://www-5.dodge.com/wccsapp/unive...ull&category=R
Here are the codes for an 03 and they are pretty much applicable to newer years too.
VIN POSITION INTERPRETATION CODE = DESCRIPTION
1 Country of Origin
...1 = Manufactured By DaimlerChrysler Corporation
...3 = Manufactured By DaimlerChrysler De Mexico
2 Make D = Dodge
3 Vehicle Type
...2 = Incomplete with Side Airbag
...3 = Truck with Side Airbag
...6 = Incomplete Less Side Airbag
...7 = Truck Less Side Airbag
4 Gross Vehicle Weight Rating
...G = 5,001-6000 lbs.
...H = 6,001-7,000 lbs.
...J = 7,001-8,000 lbs.
...K = 8,001-9,000 lbs.
...L = 9,001-10,000 lbs.
...M = 10,001-14,000 lbs.
...W = Buses/Incomplete Vehicles with Hydraulic Brakes
5 Vehicle Line
...A = Ram Pickup 4X2
...U = Ram Pickup 4X4
6 Series
...1 = 1500
...2 = 2500
...3 = 3500 Less Dual Rear Wheels
...4 = 3500 With Dual Rear Wheels
7 Body Style
...6 = Conventional Cab
...8 = Quad Cab Full Rear Doors
8 Engine
...K = 3.7L 6 cyl. MPI Gasoline
...N = 4.7L 8 cyl. MPI Gasoline
...D = 5.7L 8 cyl. SMPI Gasoline
...6 = 5.9L 6 cyl. Turbo Diesel
...C = 5.9L 6 cyl. Turbo Diesel High Output
...W = 8.0L 10 cyl. MPI Gasoline
...Z = 5.9L 8 cyl. SMPI Gasoline Light Duty
9 Check Digit 0 through 9 or X
10 Model Year 3 = 2003
11 Plant Location
...S = Dodge City
...G = Saltillo
...J = St. Louis (North)
12 thru 17 Vehicle Build Sequence
Old Mar 19, 2007 | 02:58 PM
Tmc243's Avatar
I think I got it!
The 4 digits above each item are the build codes.
Hope this helps.
APAS
MONOTONE PAINT
BAZS
136 AMP ALTERNATOR
BRTS
ANTI-LOCK 4-WHEEL DISC BRAKES
CGDS
FRONT HEIGHT ADJUST SHOULDER BELTS
CG1S
NEXT GEN MULTISTAGE FRONT AIR BAGS**
CKES
FLOOR COVERING CARPET
CLAS
FRONT FLOOR MATS
CSPS
PASSENGER ASSIST HANDLE
CUES
REAR UNDERSEAT COMPARTMENT STORAGE
DGBS
ALL 4-SPEED AUTOMATIC TRANSMISSIONS
DJQS
5,200# FRONT AXLE
DMES
3.73 AXLE RATIO
GACS
TINTED GLASS WINDOWS
GNMS
PASSENGER SIDE SUN VISOR W/MIRROR
GVBC
ALL VEHICLES W/POWER MIRRORS
GXMS
REMOTE KEYLESS ENTRY
HGBS
DASH LINER INSULATION
HGFS
FLOOR TUNNEL INSULATION
I22S
ROUTE 22 - UP, BELVIDERE, IL
JAYS
INSTRUMENT CLUSTER W/TACH
JCBS
120 MPH PRIMARY SPEEDOMETER
JHAS
VAR INTERMITTENT WINDSHIELD WIPERS
JJAS
CIGAR LIGHTER
JJBS
DUAL NOTE ELECTRIC HORNS
JJJS
12V AUXILIARY POWER OUTLET
JPBS
POWER LOCKS
JPDS
POWER WINDOWS, DRIVER ONE-TOUCH
LBCS
GLOVE BOX LAMP
LMAS
HALOGEN HEADLAMPS
LPES
CARGO LAMP
MBFS
BRIGHT REAR BUMPER
MCMS
BODY COLOR UPPER FASCIA
MCTS
BRIGHT FRONT BUMPER
MDAS
FRONT LICENSE PLATE BRACKET
MGAS
RAM'S HEAD BADGE
MHAS
BLACK WINDSHIELD MOLDING
MUSS
4X4 BADGE
MWDS
REMOVABLE TAILGATE W/CALIPER LATCHES
MXBS
FRONT AIR DAM
NFUS
34 GALLON FUEL TANK
NHMS
SPEED CONTROL
NMCS
HEAVY DUTY ENGINE COOLING
QR4S
FLAME RED CLEAR COAT
RAAC
ALL RADIO EQUIPPED VEHICLES
SBES
POWER STEERING
SFBS
FRONT HEAVY DUTY SHOCK ABSORBERS
SGBS
REAR HEAVY DUTY SHOCK ABSORBERS
SHAS
FRONT STABILIZER BAR
SUAS
TILT STEERING COLUMN
TBBS
FULL SIZE SPARE TIRE
TBMS
TIRE CARRIER WINCH
WF1S
17 STEEL SPARE WHEEL
WLZC
ALL ALUMINUM WHEELS
XA8S
NON ADJUSTABLE PEDALS
XBSS
PICKUP BOX
XFUS
TRAILER TOW W/4-PIN CONNECTOR WIRING
YAAS
BUILD TO U S MARKET SPECIFICATIONS
1AAS
U.S. DEALER RETAIL
151S
ZONE 51-CHICAGO
5IFS
DH-VEHICLE FAMILY
5I4S
FOUR WHEEL DRIVE (4WD)/(4X4)
5ZES
6 1/2 FT. CARGO BOX
5ZKS
QUAD CAB
5ZMS
2500 GVW
594S
VEHICLE ORDER TRACKING
6USS
LABEL - U.S. SPECIFICATIONS
650S
WISCONSIN STATE CODE
950S
VL
LEATHER TRIM 40/20/40 BENCH SEAT
-DV
DARK SLATE GRAY
ADB
PROTECTION GROUP
AHC
TRAILER TOW GROUP
AHD
HEAVY DUTY SNOW PLOW PREP GROUP
A76P
5.9L TD ENG(ETH)/4SPD A/T 48RE (DG8)
BCQP
750 AMP MAINTENANCE FREE BATTERY
CBEP
40/20/40 SPLIT BENCH SEAT
CMA
HEATED FRONT SEATS
CSXP
REAR 60/40 SPLIT FOLDING SEAT
CVHP
FRONT CENTER SEAT CUSHION STORAGE
CVNP
FOLDING FLAT LOAD FLOOR STORAGE
CV2P
O/HEAD CONSOLE W/TRIP COMPUTER/UGDO
DG8
4-SPD. AUTOMATIC 48RE TRANSMISSION
DHAP
LOCK-UP TORQUE CONVERTER
DH3P
ELEC SHIFT-ON-THE-FLY TRANSFER CASE
DRQP
11.50 REAR AXLE
DSA
ANTI-SPIN DIFFERENTIAL REAR AXLE
ETH
5.9L HO CUMMINS TURBO DIESEL ENGINE
GFDP
REAR SLIDING WINDOW
GNCP
SUN VISORS W/ILLUM VANITY MIRRORS
GNKP
REAR VIEW AUTO DIM MIRROR
GPG
POWER TRAILER TOW MIRRORS, FOLD-AWAY
GXXP
SENTRY KEY THEFT DETERRENT SYSTEM
HADP
AIR COND'ING W/DUAL ZONE TEMP CNTRL
JBMP
INSTR. PANEL SPORT BEZEL
JTDP
POWER 6-WAY DRIVER/PASSENGER SEATS
LBDP
ASH TRAY LAMP
LCLP
FRONT DOME W/ON/OFF SWITCH LAMP
LDAP
UNDERHOOD LAMP
LNC
CLEARANCE LAMPS
LNJP
FOG LAMPS
LSAP
SECURITY ALARM
MF1P
BRIGHT/BRIGHT GRILLE
MJBP
CHROME BODYSIDE MOLDING
MTEP
LARAMIE BADGE
NAA
FEDERAL EMISSIONS
NHBP
AUXILIARY TRANSMISSION OIL COOLER
NHNP
ELECTRONICALLY CONTROLLED THROTTLE
NZCP
CURRENT GENERATION ENG CONTROLLER
PR4A
RBQP
AM/FM CD 6-DISC RADIO
RCKP
7 INFINITY SPEAKERS
RDDP
FIXED LONG MAST ANTENNA
RDZP
STEERING WHEEL MOUNTED AUDIO CTRLS
SCVP
LEATHER WRAPPED STEERING WHEEL
TT5
LT265/70R17E OWL ON/OFF RD TIRES
TZGP
BF GOODRICH BRAND TIRES
WGDP
17X8.0 FORGED ALUMINUM WHEELS
WMJP
CENTER HUB
XCZP
TOLUCA PAINTED CARGO BOX
XEAP
TOW HOOKS
XEFP
TRANSFER CASE SKID PLATE SHIELD
XFHP
HITCH - CLASS IV RECEIVER
XFKP
7 PIN WIRING HARNESS
XJL
FRONT HOOD PROTECTION SHIELD
YGMA
10 ADDITIONAL GALLONS OF DIESEL FUEL
ZEKP
SPRING - LEFT FRONT
ZGRP
SPRING - LEFT REAR
ZTJP
SPRING - RIGHT FRONT
ZVRP
SPRING - RIGHT REAR
Z7CP
GVW RATING - 9000#
2THA
CUSTOMER PREFERRED PACKAGE 2TH
2UH
CUSTOMER PREFERRED PACKAGE 2UH
4EA
SOLD VEHICLE
4KZP
4X4 TRACKING
4X6A
WISCONSIN ACT-13 RECOVERY
4ZMA
ADJUSTABLE PEDALS DELETE CREDIT
5B3
CARGO BOX TRACKING
Old Mar 19, 2007 | 03:15 PM
belgianmagic's Avatar
Where Did You Get All That Info...wow !
Old Mar 19, 2007 | 03:55 PM
Tmc243's Avatar
Got it from work
Old Mar 19, 2007 | 04:04 PM
CTD8939's Avatar
Thanks TMC243. That is EXACTLY what I was hoping to get.
Old Mar 19, 2007 | 04:05 PM
that would make one heck of a signature...LOL
iker42
Sep 4, 2007 07:34 AM
cLAYH
Nov 26, 2006 10:00 PM
BigDave12768
Jul 9, 2006 12:46 AM
kawi600
Feb 27, 2006 07:20 PM
ldeane
Dec 22, 2003 02:59 PM
