vacuum pump
Old Feb 27, 2008 | 11:48 PM
frank compagnon's Avatar
vacuum pump
with the key in the run position , is the vacuum pump supposed to be running and do it stay running while the engine is running or is there a vacuum switch to shut it off. 03 ram
Old Feb 28, 2008 | 09:19 AM
ChrisM55's Avatar
the vacume pump is a gear driven pump that only runs when the truck is running. If you hear something running it is probably your lift pump for the fuel system and it should only run when the key is in run
Chris
Old Feb 28, 2008 | 09:35 PM
the pump that i am talking about is the one under the hood ,pass. side near the hood hinge. its a black plastic unit about two handfulls big.
Old Feb 28, 2008 | 09:46 PM
vzdude's Avatar
DTR's 'Go to Guy'
It is controlled by the pcm. Only runs when it needs to......cruise, ect.
Old Feb 16, 2010 | 08:17 PM
7siuee's Avatar
what is this pump? Mine is very loud and is now running almost all the time. Very annoying.
Old Feb 16, 2010 | 08:21 PM
shiveslandscapi's Avatar
Its for your cruise and probably have a hole in your line somewhere and that is why it is running all the time.
Old Feb 16, 2010 | 08:27 PM
7siuee's Avatar
Thanks, I'll have to do some tracing & searching.
coalburner_77
17
Nov 7, 2018 07:36 PM
jimbo486
May 8, 2016 06:07 PM
powerstrokin03
Mar 19, 2007 01:00 PM
amartinson
0
May 4, 2003 01:55 PM
