Turn Signal Problems (multi-function switch)
Old Sep 23, 2013 | 02:03 PM
SHARPMACHINE's Avatar
Originally Posted by k4jjm
Good luck!
Come back to report your outcome for others with the same issue.
Thanks,
John.
Will do. Thanks
I also seen the other thread you mentioned = https://www.dieseltruckresource.com/...l-t306312.html
Old Sep 29, 2013 | 09:25 PM
fireram's Avatar
Check wires for kinks...
I finally had time to get mine apart and have a go,, The column adjustment worked for a while, till someone moved the column on me.
I found the switch looked good, but felt sloppy. I did notice some of the wires in the loom had some kinks, and one was almost broke completely.
I had the same problem with the wires in the doors that control the power windows and locks, and had to fix most of them.
So while your in there, have a good poke around with a light and check the wires for kinds and or cracks..
Good luck...
Old Sep 30, 2013 | 07:19 AM
k4jjm's Avatar
That's a great idea! Thanks for the tip.
John.
Old Jan 24, 2016 | 07:46 AM
thunderace31's Avatar
Originally Posted by nojodas67
Hi,
I'm having the exact same issue now. Did you find the problem and was it eventually fixed?
thanks,
John
My truck just started doing this all the sudden was fine the day before now I have one Low beam light and one High beam light on opposite sides and only a right Brake and turn signal light.
Did you ever find out if the Multi function switch was the issue??
Really need this fixed before the next snow as This is my Plow truck!
Old Jan 24, 2016 | 11:22 AM
fireram's Avatar
Not exactly sure if those symptoms are a result of a bad multi function switch ( turn signal ).
Last year I purchased a new switch from a parts supplier in PA. I don't remember exactly the price but it seamed cheap, Under $100 I think, compared to the canadian prices I had been checking..
There are instructions on here somewhere how to replace it without taking the steering wheel off,, Try this link:
https://www.dieseltruckresource.com/...nstall-306312/
Sorry,, don't remember exactly, but it was so easy if you can find the part cheap enough its worth just doing it to see if it solves your issues...
good luck
Old Jan 25, 2016 | 11:09 AM
PWong's Avatar
Check out ALL connecters behind the IPM (FCM + PDC).
It's the FCM that drive those lights.
Old Jan 25, 2016 | 04:34 PM
Question
That would be great if I had a clue what any of these are IPM (FCM + PDC). lol
I know you guys love your abbreviations but us lamers have no clue what they are
Old Jan 25, 2016 | 07:02 PM
PWong's Avatar
How about call it the fuse box (Integrated Power Module) under the hood.
The silver box (Front Control Module) was mounted on the (Power Distribution Center).
So IPM = FCM + PDC
Old Jan 28, 2016 | 10:56 AM
Ok so I got the Multi Function switch took the column apart plug it in before i took the old one out and still the same crap. I then Unplugged and inspected all the other connections at the IPM FCM PDC as suggested No water no issues still the same crap again.
Im now a Popsicle do to the cold temps out. Im out of ideas so Im asking for more help ideas on what the issue could be here with this pile. Im at wits end I NEED MY TRUCK
Old Aug 1, 2017 | 03:25 PM
Dixie Chopper's Avatar
Turn signal switch
This thread is why I love diesel truck resource and have been coming here for info and help since 2006!!! My 2005 did the same thing as the OP. I took the covers off and sure enough the wires were pulled pretty tight. Pulled a little slack in he wires going to the switch and put a ty rap to hold it. Working great now! k4jjm - if you see this THANKS!
k4jjm
0
Jul 26, 2011 06:38 PM
smokeyram
Aug 21, 2009 06:19 PM
smokeyram
Dec 16, 2008 07:35 PM
CanuckCTD
Sep 25, 2007 06:44 PM
Tsutter
Jan 19, 2007 07:26 PM
