turn signal problem
Old May 9, 2007 | 05:56 PM
cromulius's Avatar
turn signal problem
My left rear turn signal is not working even after I changed the bulb and the strip that holds all three light bulbs. When I have the hazards on I get voltage to the plug but I guess it is not enough power to operate the bulb and as you guys know these trucks don't have fuses for turn signals. Any ideas?
Old May 9, 2007 | 06:02 PM
wreedCTD's Avatar
I believe they are controlled by the TIPM (Totally Integreated Power Module) Hopefully someone will chime in here with some more help.
Old May 10, 2007 | 03:43 PM
zuki_dan's Avatar
I recently had a problem with my trailer lights not working and found a blown fuse on my '06. After replacing it, that still did not fix it. Later that week I installed a TST and disconnected the batteries for awhile and that seemed to reset the TIPM, My trailer lights started working again.
Old Sep 17, 2007 | 12:05 AM
megagoat06's Avatar
I have a 06 MEGA CAB and found that my left turn signal is out. The front bulb is good and working , I have replaced the rear bulb and still nothing my trailer plug has no left turn signal or brake light as well. Like maybe there is a splice some where I just dont have access to a wiring diagram if anyone does or has had this problem I would appericate some help. I know all fuses are good. I have just read about the multifunction switch and will check that in the morning for a possiable broke or pinched wire.
Old Sep 17, 2007 | 12:07 AM
vzdude's Avatar
DTR's 'Go to Guy'
More than likey the TIPM. There is a relfash to help keep thiat from happening as well. No biggie.
Old Sep 18, 2007 | 08:33 AM
campnfish's Avatar
I had a strange problem this weekend, I was pulling a utility trailer and turned on my left blinker and on the dash the right blinker came on. I turned it off and back on and it started working right (or left ). This happened a couple of times. I don't know if it will happen without a trailer hooked up or not.
Old Sep 18, 2007 | 04:06 PM
Slice's Avatar
campfish, This also happened to my 04 something in the blinker stalk is screwed up a known problem parts like 39.00 and easy to do your self. next thing to go out on yours will be the wipers...
Old Sep 18, 2007 | 10:08 PM
campnfish's Avatar
Slice, thanks for the info, I think its time for a little warranty work.
larabeejj
Feb 23, 2010 05:20 PM
MRFD715
Aug 19, 2008 05:07 PM
Frank Hog
Sep 18, 2006 09:21 PM
