Tranny fluid recommendations
Dealer overfilled and now it's burnt.
I can get Valvoline or Castrol brand at Autozone.
Should I stick with Mopar, does it matter at all?
I'll be changing the filter as well.
thank you
thank you
I run Valveoline fluids in everything. Cept the oil. I normally run Rotella T but I got the buy one get one free deal on Moblie Delvac this time.
I just finished changing the tranny and T-Case fluids. Valveoline AFT +4 Synth
Yes, the 48re
I have the service manual on cd and saw the ID numbers on the tranny it said to look for but nothing says 48 re in that number.
I don't run Bully dog or anything that ups performance.
Also, are the pan bolts right hand thread?
thanks for the help!
I use Valvoline ATF+4® in each of the trucks listed in my signature. The 2001.5 has 166,000 on the original 47RE transmission,which remains strong and trouble free. I change the fluid and filter at or around the 20k interval to keep the additive pack in the fluid fresh.
I have attached a link which may be helpful with making a decision.
http://www.centerforqa.com/licensedatf4brands.html
Thanks a bunch.
I picked up the Valvoline ATF +4 though I eyed the Coastal since it was cheaper and sold in gallons but I had never heard or it so didn't bother.
Thanks for the useful link and the heads up on needing the torx 25!
Oddly enough Autozone gives you 2 gaskets with the filter kit
I know Mobil for one, has their ATF+4 as a semi synthetic...which is odd, as all atf+4 should be full.
