Tire Valve Stem Failure
Old Jul 6, 2006 | 09:31 AM
Toto's Avatar
Hi Fellas
I think this has been mentioned before...but serious eneogh for a reminder.
I was parked (luckily) at a campsite last week when all of a sudden the front right tire valve let go....you could see where a bulge in the valve burst and the tire flattened.
Got it fixed yesterday and happened to check the drivers side...ready to go too...had it replace also...backs ok.
I don't know if this is caused by high tire preasures 60 psi or heavy diesel or crappy valves.
Perhaps these trucks need a comercial type valve or something...quite concerning.
Not good! I was luck I was not driving....costly tire and rim replacement and possible serious accident avoided.
Please check your valve stems!
Old Jul 6, 2006 | 09:41 AM
ToyKraz's Avatar
Saw this and thought I should chime in. I have a 3500 Dually. I put larger tires on and figured while I was at it I would put on the valve extensions (came with my wheels) for the inside rears. Well on a trip from Vegas to Calif someone came along side and told me my inside rear was flat. Long story short... Took it to a shop. It turns out that the extra weight of the valve extensions and the vibration caused the stock stem to shear off. One sheared off the entire brass tip of the stock stem. The other sheared off the stock sten right at the base of the wheel. That's right. Both tires were flat. BEWARE of VALVE EXTENSIONS!
Old Jul 6, 2006 | 03:11 PM
03 ant a hemi's Avatar
I just had my driver side valve stem replaced. They used a high pressure stem this time.
Old Jul 6, 2006 | 03:25 PM
1Happycamper's Avatar
My neighbour just had this happen to his 04.5.It was sitting in his drive way when it happened.He also was lucky as he just returned from MIS {races}.I think I better go and check mine also.
Bill
Old Jul 6, 2006 | 06:11 PM
Tmc243's Avatar
There are different tire valves depending on what load range tires you have on your truck. I had to print out the differences and take them to the tire store after they had installed my tires with "low pressure" valves. They had the correct ones just wasn't aware that load range E tires required a different valve.
Old Jul 7, 2006 | 08:13 AM
Toto's Avatar
Thanx TMC...I will check this out in my area.
Old Jul 7, 2006 | 07:45 PM
bmoeller's Avatar
If the valve stems are rubber/brass, replace them with all metal ones. The others tear. I had 2 go in one week, not long after I bought the truck.
IPDiesel
Jul 29, 2015 09:57 PM
groran
Dec 1, 2010 10:12 PM
sdscuba
Aug 16, 2006 09:05 AM
Tartarus
Jan 19, 2004 10:03 AM
Mopar_Mudder
Jul 16, 2003 09:10 PM
