tire camber and ball joints
Old Jul 28, 2010 | 08:50 AM
sotex's Avatar
Does anybody know the specs for camber of the '04 Dodge with 33" tires and a 4" lift ? And what's the best way to achieve that? With adjustable ball joints or offset ball joints? Or start with stock and go from there?
I ordered a set of XRF ball joints - excellent tech website on caster and camber, but no exact specs for my truck. I'd like to know before I have them installed...
Any help on this subject would be appreciated! South Texas
Old Jul 28, 2010 | 10:53 AM
Raspy's Avatar
I decided it was best to get new non adjustable or non offset ones. This gives you a starting point as to where your axle is with no play in the ball joints and it gives you a chance to see how the truck drives this way.
Make sure the tires are new or at least in excellent condition before deciding there is a problem with caster or camber.
Keep the alignment specs you get with the new joints for future reference. There seems to be some variation in caster between the left and right in the AAM axles and this could be dialed out later with an offset joint if needed.
I'm running maximum caster (bottom of the axle housing rotated forward) at the adjusters to minimize the chance of shimmy.
Mine was pulling severly with my 315 BFGs. I got new Toyos and put in new ball joints. The specs still showed the caster to be off a bit but it drives just fine now.
Old Jul 28, 2010 | 01:57 PM
bradler's Avatar
camber is not adjustable on our solid axles only caster and toe. unless something is bent/tweaked your camber should be in spec so you only need adjustable/offset bj's if you know the camber is way off. more caster (4.5+) seems good for a lot of people in helping return to center and no shimmy. toe should be in only slightly...
Old Jul 28, 2010 | 10:19 PM
Skyd Ram's Avatar
If your camber if far enough out of spec to need adjustable ball joints to correct you most likely have a bent axle housing. At this point it would also be going through axle seals pretty quickly.
Old Jul 29, 2010 | 08:06 AM
sotex's Avatar
Thanks for the info guys! Some of the local shops were pushing towards these adjustable Moog ball joints and this really helped.
South Texas
Old Jul 29, 2010 | 10:22 AM
diesel_fire's Avatar
I agree and adjustable BJ's are junk. Stick to a good BJ like the Dyna Tracs!
Old Jul 29, 2010 | 01:08 PM
bradler's Avatar
do NOT get the moogs! lots of problems with them.
Old Jul 29, 2010 | 07:49 PM
sotex's Avatar
agreed xrf bj on the way. thanks orddred from the tire club great prices.
Old Jul 30, 2010 | 10:32 PM
Raspy's Avatar
Or you just have worn ball joints. So get new non adjustable ones and record the alignment specs for later
firebill1720
20
Mar 5, 2010 09:23 AM
1985cucv
Nov 22, 2009 01:06 PM
hopak
Aug 23, 2006 11:18 PM
Seeder
Feb 15, 2006 08:15 PM
Dynocon
Mar 5, 2005 06:24 PM
