Thermometer goes wacky and Lights shut off early
What gives twice now with almost 30k the thermometer has read 132 degrees and just recently the lights shut off prematurely when the doors are open getting out groceries or what have you.
any ideas??
Jamie
any ideas??
Jamie
found it...
NUMBER: 08-026-06 REV. A
GROUP: Electrical
DATE: October 25, 2006
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 08-026-06, DATED JUNE 02, 2006, WHICH SHOULD BE REMOVED FROM YOUR FILES. THIS IS A COMPLETE REVISION AND NO ASTERISKS HAVE BEEN USED TO HIGHLIGHT REVISIONS.
THE StarSCAN(R) FLASH FILES FOR THIS BULLETIN MUST BE RETRIEVED FROM THE INTERNET.
StarSCAN(R) UPDATE CD 6.05 WAS THE LAST CD TO CONTAIN FLASH FILES.
SUBJECT:
Flash: Overhead Console Temperature Reading Inaccurate Or Dome Lamp Turns Off Too Soon
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Cabin Compartment Node (CCN) with new software.
MODELS:
2006 (DRIDHID1) Ram Truck
NOTE :This bulletin applies to vehicles built on or before May 30, 2006 (MDH 0530XX).
SYMPTOM/CONDITION:
The vehicle operator may notice that if a vehicle door is left open for longer than 20 seconds the illuminated interior (dome) lamps will turn off.
The vehicle operator may describe that the ambient temperature first displayed in the overhead console is not accurate (displays -40°C or -40°F), when the ignition switch is turned to the "On" position, then slowly updates to the outside ambient temperature as the vehicle is driven.
NOTE DO NOT reprogram the CCN if the overhead displayed temperature stays at the -40°C (-40°F) reading after driving the vehicle for MORE THAN 3 minutes and at speeds greater than 32 Km/h (20 mph). Check the system for an open circuit condition.
this may fix your problem
GROUP: Electrical
SUBJECT:
OVERVIEW:
MODELS:
SYMPTOM/CONDITION:
Thanks for the TSB tip. Mine has done it twice and both times it reads -40F and does not change until I shut it down and restart the truck. Sounds like the open circuit situation. Open circuit?? Is that dangerous?
randyswelding
Feb 9, 2009 10:40 PM
CACalomino
20
Jun 26, 2007 07:19 PM
converteddzlr
Jul 29, 2005 01:35 PM
