Is there wear indicator tabs on my brakes?
Old Dec 4, 2009 | 04:22 PM
cromulius's Avatar
The dodge in my sig. Wear tabs? Thanks.
Old Dec 4, 2009 | 04:48 PM
Guardrail's Avatar
No, but they tend to squeal when a groove is worn in the rotor and a slight ridge is formed at the outer edge that rubs on the pad.
Old Dec 4, 2009 | 05:32 PM
gcssr's Avatar
yes; tabs were on my 04.5 when i replaced them at 98203 miles, just started to rub. bought factory new front pads at bluebonnet dodge, new braunfels tx.
$70.03 tax included. figured if these last as long as original, i will be good to
200k.
Old Dec 4, 2009 | 05:54 PM
bansh-eman's Avatar
200k.
each or for a pair? Did you spin your rotors?
Old Dec 6, 2009 | 10:21 AM
cromulius's Avatar
Mine are making a squeel at less than 36k. Dealer said they are covered for 12k which I assumed I guess. Towing the boat with no trailer brakes is the assumed culprit. Time for a brake job. Any tips since it may be different than my chevy?
Old Dec 6, 2009 | 11:30 AM
.boB's Avatar
Disc brake squeal is not always caused by worn pads. Pull a wheel off and look before spending money. The pads may have plenty of life left in them.
Old Dec 6, 2009 | 11:32 AM
safecracker909's Avatar
No difference. If you've got the time and money. Consider upgrading our rotors to slotted rotors to help keep the temps down while pulling a trail with no brakes.
Old Dec 6, 2009 | 11:38 AM
annabelle's Avatar
X2....true with mine.
Old Dec 6, 2009 | 12:19 PM
justin mcfall's Avatar
X3..Just put new brakes on mine last year,they are squealin again..
Old Dec 6, 2009 | 12:50 PM
billie's Avatar
A bit of good quality silicone between the plunger and pad can work most times.
Old Dec 6, 2009 | 03:30 PM
.boB's Avatar
Slotting does nothing to dispel heat. The purpose of the slots is to act like a cheese slicer. Every time the slot goes over the pad, it removes a small amount of material. When you're racing that's a good thing; it shaves off the glazed surface causes by heavy use and high heat levels. The down side is that you lose a lot longevity. My track car goes through 3 sets of front pads a year.
If you're worried about heat, add cooling ducts.
spansil
May 12, 2008 11:18 PM
blackdiesel
Feb 11, 2007 07:47 PM
Oilguy
Jan 22, 2007 07:37 AM
Bradtothebone
Dec 24, 2003 12:07 PM
David Gardner
May 13, 2003 03:54 PM
