Sway bar end link install?
Old Sep 8, 2010 | 12:01 PM
surfram's Avatar
My sway bar end links have been making a racket for a while and now the driver's side is looking slightly askew at the boot. I will probably order a set of maxx links from summit (part# 1226) this week. Is this a simple remove/replace with hand tools or do I need anything special to complete this job? Torque wrench settings?
Old Sep 8, 2010 | 02:32 PM
Dodgezilla's Avatar
I needed a tie rod tool to break mine free but other than that it was pretty easy.
Old Sep 8, 2010 | 04:31 PM
Shorts's Avatar
Fairly simple job. Mine about fell out. Toughest part is holding the bottom cup/bolt in place while torquing the nut on the MaxxLink (use a screw driver before installing the new bolt shaft in place - make sure it's aligned properly)
Torque values are fairly low. I think 40ftlbs on the bottom nut and on the top nut barely enough to squish the bushing even with the edge of the washer.
Old Sep 8, 2010 | 05:55 PM
JP-4.5's Avatar
I have also been told MaxLink is a good product to use. They show an extended unit for lifts.. If a user has taller tires should the longer MaxLinks be selected?
I have 34" tires on my truck and stock tires were 31.5" Should I be using the extended Maxlink or stock length?
Old Sep 8, 2010 | 05:58 PM
Shorts's Avatar
The extended length (designated by the "L" at the end of the part number) should be used for trucks with a leveling kit. Otherwise use the regular length.
I used the extended length since I've got a leveling kit.
Old Sep 9, 2010 | 10:47 AM
bhuffstutter's Avatar
Easy job with simple hand tools, I had to use a BFH to get the old ones out. Other than that took me about 20 min to do.... Shorts is right the L designation is for leveled trucks.. Maxx links comes with instructions with torque specs... Good luck....
Old Sep 9, 2010 | 11:49 AM
kry226's Avatar
Unless you have drop blocks between the frame and the sway bar mounts, which effectively keeps the OE sway bar geometry. Then use the normal, non-lifted links.
ROOFGOOF
Jul 16, 2015 01:44 PM
mdbrown
Dec 26, 2009 08:48 PM
gresh1003
Aug 20, 2009 05:57 PM
mitternocht
Feb 11, 2008 08:45 PM
Syndicate
Jan 9, 2008 07:19 PM
