2wd Sway Bar Diameter/End Link Bushings - Replacement
Old Dec 20, 2009 | 10:25 AM
mdbrown's Avatar
From: Laughlin, NV and on Lake Fork east of Dallas.
Hi All,
I'm looking to go to polyurethane bushings for my front sway bar mounts and end links. I've used Energy bushings on other trucks, but will have to go with Energy universal sizing for this project, as they don't have a vehicle specific set of bushings per their website catalog.
So, I need to know the diameter of the of the stock sway bar on my 2004, 2wd, 3500. I don't have calipers, so I don't have a good way to determine the exact diameter.
If anyone out there can provide this info, along with the size of the end link bushings needed, it would be greatly appreciated.
Thanks
Old Dec 20, 2009 | 11:39 AM
.boB's Avatar
Got a set of open end wrenches? They're pretty good for measuring the diameter.
Old Dec 20, 2009 | 01:12 PM
MikeyB's Avatar
I measured mine, 1.18" (30mm).
MikeyB
Old Dec 21, 2009 | 09:38 AM
mdbrown's Avatar
MikeyB - Did you swap out your rubber bushings for polyurethane ones? Did you use polyurethane end link bushings?
If so, I would love to know what brand/size you went with.
Thanks
Old Dec 26, 2009 | 02:20 PM
Rednax's Avatar
Mine needs this done, too. Have upgraded our two 2WD Jeeps this way as well as other cars in past. Poly bushings here, and on shocks, is a noticeable upgrade for steering precision.
Old Dec 26, 2009 | 08:18 PM
Sevir's Avatar
are yall getting a clunking where you turn or hit bumps. i am getting this, it sounds like teeth on a bolt is scrapping or something like that. I troubleshot it down to the sway bar but just havnt replaced it yet.
Old Dec 26, 2009 | 08:48 PM
MikeyB's Avatar
Thanks
Nope, still running the originals. Every once in a while I'll hit them with some silicon spray to prevent galling.
I did have to replace both end links a few months ago, not because of the bushings but from the ball joints being worn out and rattling. I went aftermarket using Deeza.
MikeyB
4xfourfun
0
May 22, 2015 09:02 PM
bishgeo
Aug 7, 2010 11:07 AM
gresh1003
Aug 20, 2009 05:57 PM
RAM3500 C&C
Dec 7, 2006 04:15 PM
